Question about Sewing Machines
Can you tell me how to thread a union special 39200b thank you Regards Jean Miller
How to thread a union special overlock machine ??
check with sewusa for a threading diagram
Feb 01, 2016 | Sewing Machines
How do i use jean thread on my juki industrial sewing machine
are you using a denim needle for sewing jeans?
where is the thread getting caught up at?
make sure the bobbin is turned the right direction in the bobbin case
Feb 13, 2013 | Juki Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Manual for union special 430-2 sewing machine
Hello
Try these links.
www.usa-dealer.net/COLUMBIA-UNION-SPECIAL-43... - United States
www.jatonkam35s.com/M809series/TM9-2320-260-34P2.pdf
http://www.dataentryjobs.us/67948.html
Feb 07, 2012 | Sewing Machines
I bought a yamata fy-900 from a thrift store. used it for a couple of days, it worked fine untill i tryed to sew a pair of jean pants and the needle got stuck and it hasent worked right sence it does not...
You have probably knocked out the timing on the machine. Most household machines, inexpensive machines especially will not sew denim without a fair amount of coaxing. Check the threading and do try on lighter fabrics first. to see if its just the denim.
Derek
Jan 17, 2011 | Yamata FY900 Mechanical Sewing Machine
Need manual for white blue jean sewing Model 1599 serial 003645
i was able to find one at www.ifixmachines.com
Jan 29, 2010 | White Sewing 1521
Thread breaking during sewing on Ericco sewing machine
replace the needle, use a heavier thread, insure the material is advancing properly as you sew.
Feb 08, 2009 | Singer Sewing Machines
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Sewing Machines Logo
174 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
