Question about OmniMount 3 SHELF A/V TWR BLK Full Tower Case
I just bought an OmniMount TRIA Adjustable 3-Shelf Wall Component System with Cable Management. How do I hide the plug in, where you plug your tv into the wall ?
  • 326 Answers
You can either run the power cable with an extension through your wall component system, run it along the wall and purchase an on wall wire concealer, or you can move the power outlet from down below to up near your tv.
Your local cable company SHOULD be able to do this for you if you don't want to mess with it.
Here's the on wall concealer.
http://www.bestbuy.com/site/Wiremold+-+Flat-Screen+TV+Cord+Cover+Kit+-+White/9058743.p?id=1218013803132&skuId=9058743&st=wire%20concealer&cp=1&lp=3
Posted on Mar 16, 2011
Testimonial: "Thank you very much, I will try an extension cord, if that doesn't work then I will get the wall wire concealer. Thank you"
Tip
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
on Aug 09, 2011 | Apple iPod touch
Tip
Installing a fllat screen tv on the wall
We have found many people facing the bodacious task of mounting a large or medium flat screen on a wall. The following should help considerably.
You Will need a helper so know one gets injured. Attach the brackets to the Wall using heavy duty 3/8 x 3 long lag bolts. Use a level for straightness.
If you wish to hide your wires behind a wall for a much nicer set up.
Drill a hole in between the bracket centers on the wall and then use a electricians fish tape to run the rest of your wires. You may repeat this step for speaker wires.
Last thing is to lift your unit up onto the bracket. Danger- This TV can be very bulky and heavy. Place your wires through the holes first before hanging.
Plug in your HDMI cable to the Flat Panel and route to the manufacturer's designated component.
on Feb 22, 2010 | Audio Players & Recorders
Omnimount tv mount strong enough to hold?
Even though there is a significant weight difference, your Omnimount might not be adaptable but I advise working carefully if you try it to avoid an expensive crash.
Nov 09, 2013 | OmniMount FP-CL Medium Cantilever Mount...
How does the tv mount?
1- remove the wall plate from the arm.
2- fix the front plate to the back of your television.
3- mark the position of the holes and drill
4- put wall plugs into holes.
5- secure the wall plate to the wall
6-attach the arm to the wall plate.
7-hang the screen on the arm (i recommend having someone help) and secure it in place
Mar 05, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
No mounting instructions in package. will it work on an LG 47 inch led tv? To many peices in the package?
It should work with the LG 47". you need to find the correct bolts that fit the mounting holds on your TV. There should be a bag of bolts packaged with the Omnimount.
Feb 28, 2011 | OmniMount 40" 70" TV Wall Mount
Do i just drill into the drywall and hang there or do i use the studs
Several people are killed every year by having insecure wall mounted TV's fall on them.
You would be advised to screw into stud-work if possible. Otherwise use hollow wall fixing bolts (toggle type) to make sure that the screws don't pull out.
Feb 10, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
Picture is black and white with a dvd movie
If you're using the 3 component cables for video, one is probably defective or not connected well.
Dec 29, 2009 | Bose Lifestyle 38 System
Ive got bose lifestyle model 5 system and have just bought a samsung led tv, how to I connect up the bose to the tv??
There should be an AUDIO OUT left and right rca input/output plugs on the back of te TV; according to this, (http://www.bose.co.uk/GB/images/Lifestyle%205%20Series%20II%20Music%20System_tcm6-4083.pdf) the inputs for the audio are right next to the FM antenna port/plug so, if you have one of these; (http://www.inmax.ca/images/rca-cable.gif) just plug them in to the AUDIO OUT on your TV, and into the INPUT on your Bose system.
Aug 12, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
OmniMount 3 SHELF A/V TWR BLK  Full Tower Case Logo
129 people viewed this question
Top OmniMount Computers & Internet Experts
David Payne
David Payne
Are you an OmniMount Computer and Internet Expert? Answer questions, earn points and help others
