Tv has no picture. I was connecting RCA cable from my computer to tv and put the wrong connections on to the tv, now the picture is gone but the sound still works and also does the on-screen settings
  • 325 Answers
I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
If you have menus then you may have also shorted your mainboard (AKA tuner board)
Posted on Mar 16, 2011
  • shash_128 Mar 16, 2011
    Thanks for your help! I don't know much about fixing tv's but if I try fixed it myself is it possible? If so how would I go about doing it? If i open up the tv where would I find the 24v line?
  • Andrew P.
    Andrew P. Mar 16, 2011
    The 24v line will be marked on the power supply (stamped on there). You need to be careful with highvoltage. I've done this a lot and you need to be careful. It is possible to do yourself with the right research and plan correctly.
    Please rate if this helped :)
I want to connect a Multisync 1860 NX to a DVD player
You just need a RCA cable have a Y,R,W colors male inputs wire both sides.One side of the RCA cable Y,R,W colors inputs plug in the IN HOLES Y,R,W in the tv.The other side of the RCA cable wire inputs to the OUT HOLES to the DVD player.Push your tv in modes like video 1 or 2 or IN put buttons on the tv or on the tv remote.Now your tv should a have playing video picture.
Dec 11, 2012 | Computers & Internet
I JUST CONNECTED THE PC TO TV WITH VGA TO RCA CABLE BUT PICTURE WON'T COME ON THE TV SCREEN
Make sure that you have the correct display mode selected. While many connections like a VGA to VGA connection will automatically detect, I don't think a VGA to RCA adapter will. Go to control panel/display and see if your computer has detected the second display.
Also make sure the RGB or RCA is selected as the input source on your TV.
Once these are both set correctly you should be in business!
Dec 21, 2011 | Computers & Internet
For some reason anything I connect to the TV is only black and white. I tried both the Video connection on the side and in the rear of the TV. I know it's a color TV, so what could be wrong?
Tries another set of RCA component video cable to the tv cable out put holes.The RCA set of cable u are using now,the Yellow connection color wire that supported video,could be bad that why u not getting any colors video.
May 08, 2011 | TruTech T2000D TV
Want to connect my thinkpad to the Olevia 532-B12 CD TV. Cables I have found show 15pin conenctors for the video and signle RCA plugs for audio. The back of the TV indicates it needs an audio splitter...
what connections to you have on your computer? because it is best to match connections with tv to computer. s video? hdmi? they sell av or color stream cables with a splitter to connect to computer color stream is just for picture av (RCA input) is for both video and sound.
Jan 31, 2011 | Olevia Televison & Video
My flat screen tv/dvd combo has sound but no picture... but when we put a dvd in there, it does show a picture! What could be wrong??? Help!
If u able to have picture watching a dvd,than it not ur tv is the problems.Ur tv connected to a cable,satalite or a Telicom boxes?Unplug,replug these boxes about an hour later,let it reset it self,upgrade it software.Ur tv should have it picture back.
May 21, 2010 | RCA L42WD22 42 in. LCD Television
Why does my tv say wrong region everytime i put
checked where you plug-in the cable, if it is correct. maybe a loss connection inside tha tv,.. need to be solder
Jul 31, 2009 | RCA 20F514TD 20" TV
Connected AV cables correctly. DVD is reading.No picture.
have you put your tv onto av1 through the remote
Jun 06, 2009 | Televison & Video
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Will not show picture on disc
Check the RCA wire or fiber optic conection. If you use RCA wire be sure you put Video output from your DVD to input Video of your tv set.
Apr 16, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Open Questions:
Televison & Video Logo
492 people viewed this question
Top Televison & Video Experts
Electro Med Services...
