Question about GPS
Need fuse no. of cigarette lighter - GPS
  • 391 Answers
Hi you will need to get a 10amp fuse for this system can be got at any garage hope this helps
Posted on Mar 16, 2011
I need to find the cigarett lighter fuse
the fuse box under dash board passengers side fuse no6 10amp rear cigarette lighter fuse no8 10amp front cigarette lighter
Jun 19, 2016 | Cars & Trucks
Where is the cigarette lighter fuse located in a 97 buick century?
GOOGLE is your friend! Open up Google then search for this exact phrase (without the quotes)
"97 buick century cigarette lighter fuse location"
Aug 05, 2014 | TRUCKSPEC TSP-311 12-Volt 2 Outlet Fused...
Cigarette lighter
check the fuse box inside the truck and under the hood 1 should be marked for cigarette lighter or Power Point or accessory if you did not out you need to pull the cigarette lighter from the dash so you can get to the wires in the back of the lighter and then test the wires with a test light to see if it's getting power probably just a piece that's what generally goes wrong
Jul 04, 2013 | Vehicle Parts & Accessories
Where to find fuse for cigrette lighter
Fuse number 18 20amp is for cigarette lighter.Its located in the trunk compartment fuse box. ------- If you need fuse box diagram showing the cigarette lighter fuse.Click the link below and see the diagram:---
http://technoanswers.blogspot.com/2011/10/where-is-cigarette-lighter-fuse-located.html ---------- This will help.Thanks.Helpmech.
Oct 10, 2011 | 1994 Cadillac DeVille
Looking for cigarette lighter fuse location...
Look for the accessories fuse in the fuse panel. If the fuse is still good then you cigarette lighter is burnt out and will need to be replaced. Hope this will help you.
May 20, 2010 | Cars & Trucks
Where is the fuse for cigarette lighter. fuse
Hi! The cigarette fuse is somehow interconnected with the radio fuse. If no luck, then i believe that the cigarette lighter needs to be replaced. Hope this helps and have a good one!
Apr 20, 2010 | 2003 Mercedes-Benz C-Class
Need location of fuse box containing cigarette lighter fuse
On some vehicles the cigarette lighter fuse is attached to the cigarette lighter assembly itself. Check if you can gently prise the cigarette lighter assembly out of its location in the dashboard, or remove any panel that may allow access to the rear of the cigarette lighter and look for the fuse (it may be an in-line one in the power lead to the cigarette lighter or it may be physically attached to the cigarette lighter itself). Failing that, the fusebox is normally under the dashboard on the driver side, but some fuseboxes can be found under the dashboard on the passenger side. There should be a diagram under the fusebox cover that shows what circuits each fuse protects. If a fuse has blown ensure that another of the same type and value is used to replace it.
Dec 25, 2009 | 2004 Dodge Neon
The cigarette lighter isn't working
on a right hand drive s type the fuse for the cigarette lighter is under dash right hand side it is fuse no 32 20 amps
Apr 28, 2009 | 2000 Jaguar S-Type
Need to know fuse numbers
number 32 is the front cigarette lighter fuse 2 and 27 for the audio unit which i presume means radio
these are in the fuse panel under the dash on the drivers side
Feb 26, 2009 | 2002 Lincoln LS
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
