Question about LG WM2301HW Front Load Washer
I had a lot of sheets and a couple of towels in the washing machine and it eventually the load just stopped before the spin cycle(dial on sanitary mode) I drained the water and tried to drain and spin and all I hear now is a clanking sound and it's not spinning, sounds like a cog spinning and not catching on anything...not sure what is happening. I took out all the sheets and the same thing is happening, please help!!!
  • 30 Answers
Thank you for using FixYa. Does the drum of your machine appear to move freely when turned by hand? If it does with no resistance, I would say that the drive belt has either come off the motor or it has perhaps been placed under a strain with a "heavy" wet load and and snapped. The drive belt can be accessed through the panel on the rear of the machine. If the belt has simply come off, run the belt round the small pully wheel on the motor and then work it onto the large wheel on the back of rhe drum. Turning the large wheel on the back of the drum in a clockwise direction whilst guiding the belt on will make matters easier.
I hope this as helped. If so please place a Most Helpfull vote
Regards
Duncan
Posted on Mar 16, 2011
  • zulu1999 Apr 22, 2011
    I had the same symptoms, but a totally different problem which was even easier to solve. When I opened the back, I noticed the bolt that holds the spin wheel onto the motor had fallen off! All I had to do was replace it firmly and it worked again.
After 3 years spin cycle has become almost
1st the machine has to be completely level--also take off the top--there should be two springs at the top and there are also shocks at the bottom--make sure none hav come offf
Oct 27, 2009 | Malber P25 Front Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer not spinning, nor draining
check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Dec 27, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Maytag atlantis wont spin cycle
this could be one of three things, 1. Rinse hold (an option to save the washing sitting crumpled when you are out) release the rinse hold button and it will spin.
2. You have a blocked drain or uneven load (if a washing machine spins with a full load of water in it it would dance around your kitchen and eventually break apart the weight is too much, it has to remove the water to a level within a set time or it will stop, or if its a uneven load it will attempet 3-4 times start a spin.
3. your motor brushes are worn (brushes last around 2-3 years depending on use) or board failure, first signs of this can be it will not spin, then it will not rotate at all try to spin it with no load (no washing) then add a couple of wet towels. if no spin it could be either of the two best way to check the brushes is to remove them and check the length they start around an inch long.
Always isolate the electrical supply when removing things from the machine.
Nov 12, 2008 | Maytag Washing Machines
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
LG WM2301HW Front Load Washer Logo
102 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
