Sir hw can set my dpi setting i can change dis due to this reason my font size wii be long nd if i was triyin to bring default then its is nt possiple by me so give me solution how can set as default my dpi setting
    Genius:
  • 1,189 Answers
Hi skyabhi_cold, to change the {DPI Settings}.
Right click on a 'empty area of the "Desktop" screen.
sir hw can set my - paul7of9_183.jpg Select the "Personalize" shortcut when the window open!"
Next, in the [right column] "Tasks" area.
Click on the "Adjust font size (DPI)."
Now, click on the Default scale {Radio Button}.
_987.jpg "You can also make "Adjustments to Customize the {DPI}."
Click on the [Custom DPI...] button.sir hw can set my - _988.jpgc="http://i.fixya.net/uploads/images/_988.jpg" alt="_988.jpg" classir hw can set my - _989.jpg />
_989.jpg "Drag the "Ruler" for (Pecentage size = 100% < 75%...}.
Click on the "Apply, and OK buttons; when finished!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Posted on Mar 16, 2011
  • paul7of9
    paul7of9 Mar 18, 2011
    This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
Normal size for dpi
DPI, or "font size" is variable, depending on your monitor's native resolution, The resolution you have selected for it in Windows (Desktop-->Properties[right-click]-->Display Properties-->Settings), and what program you are currently using (browsers can be "zoomed").
I would try adjusting your monitor resokution first, before changing display font size. Try this page for some help with XP: http://www.andybrain.com/qna/2008/02/09/how-to-change-the-font-size-in-windows-xp/
This page for help in Win7: http://www.sevenforums.com/tutorials/443-dpi-display-size-settings-change.html
There really is no such thing as "normal" DPI font size. Most people with decent eyes would probably use 96 as a standard.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
Jun 22, 2011 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
SIR i he laptop maine dpi setting change kar di jis karan sare font bahut bare ho gye hai aur ab wo phir se chote nahi hone ke karan sab kuch bahut bara dikhai de raha hai ple is sahi kaise kare bata de
Agar aap Vista Isthamaal kar rahe hain tho, Control Panel Kholiye aur Personalization mein jayiye. Adjust Font Size(DPI) per click kariye(red box se mark kiya tha maine)
Default size 96 DPI select kariye aur OK dabayiye. Problem solve hojayega
Mar 16, 2011 | Computers & Internet
How do I increase and set font size?
First, right click on your desktop and click on Personalize. Alternatively, you can go to Control Panel -> Appearance and Personalization -> Personalization.
In the Personalization window, go to the left pane and click on Adjust font size (DPI).
If UAC is turned on you will need to make an additional confirmation so that the DPI Scaling window will launch. You can choose the default scale of 96 DPI or a larger one of 120 DPI, which makes the text more readable. If these two options are not enough you can click on the Custom DPI button and choose another size (DPI).
In the Custom DPI Setting window you can select the desired percentage for the DPI increase. You have the following options: 100% for the normal size of 96 DPI, 125% for 120 DPI, 150% for 144 DPI and 200% for 192 DPI.
If you set the DPI higher than 96, and you are running Windows Aero, the text and other items on the screen might appear blurry in some programs that are not designed for high-DPI display in Windows Vistamag-glass_10x10.gif. You can avoid this issue by using Windows XP style DPI scaling. Just check the appropriate option and press on OK.
The change can be applied only after a system restart. Close all the running applications, save your open documents and then press on Restart Now. After a reboot, the font size will be changed.
Feb 06, 2011 | Dell XPS Laptop with Intel Core 2 Duo...
HOW DO I CHANGE THE FONT SIZE. I WANA MAKE IT LARGER.
One way to adjust/set the default size (to get a larger font size) is through your Control Panel - Display - Settings window, where you can select a larger font.
If you are using a browser (e.g. Internet Explorer), there is way to increase (or decrease) the font size (displayed on the screen) using the "magnification" option at the bottom right corner of the screen. Simply click on the "magnifying glass" and increase/decrease the value, e.g. to 150% .
Jan 02, 2011 | Acer Aspire One PC Notebook
How do I make my font and text size bigger?
If you want to make font and text larger in a Word document, just look at the taskbar and click font pull-down window (usually the default is Times Roman) and pick whatever font you want, then click the pull-down window (usually the default is 12) and pick a larger size.
Or you need to make a display adjustment. Click Start, Click Control Panel, Click Personalization, click Display Settings, choose Resolution up or down which will adjust icon and font size on your computer.
Or click start, Control Panel, Personalization then:
  • In the left pane, click Adjust font size (DPI). If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  • In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
  • Jan 01, 2011 | Computers & Internet
    How do I increase text size
    Are you referring to the default text size Vista uses? Then, contrary to windows XP, in Vista you have to separately increase the text size for different instances.
    1. Right click on the desktop and select personalize
    2. Select Windows Color
    3. Select the required item of which text size is to be increased.(for example: Icon, Message Box etc.)
    4. Then you can change the text size, font, color, and font weight
    Sep 19, 2010 | Microsoft Windows Vista Home Basic for PC
    Text and fonts i cant find the zoom on pc
    you can also press and hold the ctrl key then press the " + " key to make your fonts get bigger...the " - " to make them smaller. nothing technical...just a easy shortcut with keys.
    Sep 05, 2009 | Compaq Presario 5000 PC Desktop
    Can't click Accept in Software License Agreement dialog box in Ad
    This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
    May 17, 2009 | Adobe Acrobat 7.0 Professional
    Adjust font size DPI to make default as 120 DPI
    go to settings and set the display settings .
    Jan 16, 2009 | HP 2133 Notebook PC
    Computers & Internet Logo
    85 people viewed this question
    David Payne
    David Payne
