Question about RCA TruFlat 27F520T 27" TV
Our 27" Works for a
  • RCA Master
  • 11,800 Answers
The thin line image appears when the vertical deflection unit is not operational. This is a major fault for which you will have to take the tv to a repair shop - several components (starting with the vertical amplifier) will have to be replaced. In the mean time do not use the tv, or it may fail completely.
Posted on Mar 16, 2011
My kindle still works, but the screen seems to have shadows on it over my text rendering half unreadable. Can I ffix this??
I thin I know what you mean. Have you tried turning off, wait a minute and turn back on? For best results contact Amazon.com. Online under the search bar click help. Click device support, fill in info and if you leave phone number they will call back when next tech is available. It's not a long wait so send request when you have some time to talk.
Apr 21, 2016 | Amazon Kindle
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Have a fujitsu pds4229w-s it Have Have a fujitsu pds4229w-s it Have a fujitsu pds4229w-s it turns on and then have a fujitsu pds4229w-s it turns on and then when you put the video source to it its ok then...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 09, 2017 | Fujitsu Plasmavision PDS-4229 42 in....
Screen goes to a thin horizontal line
You have bad grounds on the vertical IC and bad cap at 35volts 100mf. Resolder the IC and replace the cap. Also there are two other caps you should look for...50volts 1mf, they need replaced too!
Oct 03, 2009 | Sansui DTV2760 27" TV
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
After I have been watching my ln-t4081f for a while and I turn it off, when I turn it back on again all I get are lines on the screen and no picture. I have to let it "rest" for quite some time...
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Samsung Televison & Video
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
