Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
  • 902 Answers
This is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Posted on Mar 16, 2011
Color fading from left to right
I'm sorry to hear that you're having this issue with your TV. It may be an inverter board, or something internal having to do with the backlighting of the unit. I would recommend having the unit inspected by a technician.
Nov 06, 2013 | Philips Televison & Video
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba has lost focus
The convergence ic board is dead.
Need a new one.
Aug 19, 2009 | Toshiba 51H83 51" Rear Projection...
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
1991 xj6 4L Vanden Plas body parts
yes they are interchangible except the front spoiler is different, but everything else is the same. (the front lower spoiler on the 93 has built in fog lamps)
Pretty easy repair and I could only hope his car is the same color....
JPTCAT
Oct 13, 2008 | 1991 Jaguar XJ6
Printing lighter on left side
Try cleaning the corona wire/ charge roller if this doesn't work replace the image drum
May 16, 2008 | Samsung CLP 300 Laser Printer
Toshiba tz50v51 problem
Hi!
Seems that it's not a well-known problem, but I'm adding a link to the "troubleshooting" part of the manual - hope it will help!
Aug 09, 2017 | Toshiba 51H83 51" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Large vetical bar on left side of screen
sounds like you did everything correctly?? HMMM well there is no adjustment thats for the consumer to try,your right about that. Sometimes a set can be working well and its moved ever so slightly , the Printed circuit board cracks or a solder connection becomes loose and starts giving problems. This seems to be in the width circuit or the horzontal sweep?? there are no user serviceable poarts inside these sets and there is dangerous Hi voltage so the only thing I can recomend is to have a shop take a look at it and maybe they can find the solder connection or crack in the circuit without too much trouble. Sorry I coundnt be of more assistance. good Luck
Jun 14, 2006 | Toshiba 32A43 32" TV
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
