Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Hot Air doesn't seem to cool
I am assuming it's turned on, and plugged into electricity, but at that point I have no idea what you are doing to try to cool the air, as in, what settings do you have it on?
Does the front indicator panel, led lights, have any signals indicated?
Are you exhausting air out of the room, and using both exhausts?
Are the exhaust lines straight? Pointed upward or downward? Sideways kinked?
Are there Hard S's in the exhaust lines that would cause backup of air flow?
Has a family of small penguins (very small) moved into the exhaust hoses, thereby blocking flow?
What is the actual temperature before use, and during use after a given amount of time and at what is the outside ambient temperature?
Did You lay it down or sideways before turning it on, or has it always been in the upright position?
Is the filter clean?
Have you cleared out the drainage hoses? They may be backed up.
Are your vents open?
Air in, air out.
try leveling or having the exhaust hoses point down and not up to exhaust.
Posted on Sep 17, 2008
2000 pontiac bonneville blows hot and cold at the same time
Sounds like the blend door motor isn't working.
Jan 20, 2013 | 2000 Pontiac Bonneville
What should I do in order to make sure my dog house stays cool in the summer?
In order to keep your dog's house cool during hot summer days, consider to do the following:
  • Place the dog house in the shade so it doesn't get too hot from the sun.
  • Make sure that the house is ventilated so warm air can come out.
  • If it gets really hot inside the house, you should put a fan to cool the house down or buy a small air conditioning unit made for dog houses.
  • Place a cooling mat on the ground of the house. This will help the dog to cool down during the hot summer days.
Oct 25, 2012 | Dogs
Do I need to put air conditioning in my dog house? It seems kind of extravagant.
It depends where you live, but if you live in a hot climate and suffer from the heat yourself (and use air con to cool yourself down), the chances are that your dog is suffering too. The dog house provides some shade but it doesn't help humidity and really hot temperatures.
Aug 22, 2012 | Dogs
My 1999 Chevy Malibu runs hot? It started when it overheated. We changed the thermostat, then water pump, then temp sensor gauge and the temp gauge goes high but only when the heater stops blowing hot...
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Sep 20, 2011 | 1999 Chevrolet Malibu
The air from my air conditioner doesn't seem to be coming out as cold as it was when i first bought it. It seems to take a lot longer to cool off my living room, i dont know if it needs freon to be...
Its going to take a hile to cool down a hot room . have you cehck the filter? while your at it wash it out . what is the temp of the room and the temp of the air coming out of the unit?
Jul 22, 2011 | Goldstar Heating & Cooling
2002 E350 still overheating? New Thermostat, and new spark plugs. Drained & Flushed cooling system - radiator not blocked. No leak from water pump. Catalytic converter became red hot once while reving...
With the vehicle cool, remove the radiator cap, and manually pump the lower radiator hose until all the air is out of the system. That is how you get the air out of the system. If it is still overheating from there then you should check the fan to make sure that it is working correctly.
Jun 07, 2011 | 2002 Ford E350
Driver air cool, passenger air warm or hot
Are you sure you checked the temp door ?Is it hot air ,like the heater?First check the ac compressor to see if it is actually turning,then check the large ac lines near the firewall near the windshield to see if they are cold,and sweating.If they are that rules out freon problem.The temp door might not be moving,check all selections on ac control and watch is door and see if one of them doesn`t move.If one door doesn`t move then it is the one you need to fix,if I can help,let me know.roniecon@gmail.com
Aug 20, 2009 | 2006 Jeep Commander
Honda Stream bad smell from air cond
Seems like something fell into the air system. Try replacing the cabin air filter.
Apr 05, 2009 | 2001 Honda Civic
Heating & Cooling Logo
91 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
