Question about Kitchen Ranges
Need part number for bake element. thank you - Kitchen Ranges
  • 59 Answers
If you know the model number of your kitchen range, go to this web site. Repair Clinic.com. I have found everything I have needed for my appliances on this web site.
Posted on Mar 16, 2011
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
How to solder the ends back on a bake element
If the bake element terminal was shorted and burnt off, you will need to replace the bake element with a new element. Supply a model number and brand of appliance and I will supply a part number for you. Soldering will not hold as the solder will melt and break away shorting again. Possible to spot weld it if enough terminal left.
Mar 24, 2012 | Ovens
We have a Westinghouse Continental Electric Range KHB30XKI that was installed in the early 1960's. My mother loves it. Tiny kitchen, slide out burners, space saving. Please help me find elements for...
Do the elements look like the pictures here?
http://www.repairclinic.com/PartDetail/Bake-Element/5300210961/2548 bake element
http://www.repairclinic.com/PartDetail/Bake-Element/5300210911/2183 bake elemenet
http://www.repairclinic.com/PartDetail/Heating-Element/5300210972/1070 bake element
http://www.repairclinic.com/PartDetail/Heating-Element/5300210922/609530 broil element
I hope it is one of the these the first 3 are different bake elements the last one is a broil element that the only pull out elements westinghouse used and i appears all are still available from there on repair clinic
I hope i have helped you to find the element you need,
Gene
Aug 15, 2011 | Ovens
IS THE BOTTOM OVEN COIL/ELEMENT TE SAME IN MOST 30" MODELS. MINE JUST WENT OUT. IM HAVING EASTER. NEED REPLACED. model number WHIRLPOOL MOD# TES325MQ 3
All bake elements are not the same. The part # for your bake element is #9758519. Hopefully you can find an appliance parts store in your area. Thay are fairly ease to replace. With the oven UNPLUGGED, Remove the two screws holding the element in and there should only be two wires connected to the element.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
Apr 23, 2011 | Estate White-on-White TES325MQ Electric...
Bottom heating element burned out. Can I get a new one and how do you replace it?
You will need the model number of the machine, Once you have the model number, you can call a parts store to get the part you need.
When you have the part. Very important! First Turn off the power to the machine at the breaker box or sometimes called fuse box.
There are usualy 2 screws holding the bake element in, Remove them and pull the element out untill you see the end of the element and wires attached to them. NOTE : Go slow. You will see the wires at the end of the element. Just take a look at the new one to see what it will look like. Next, remove the wires from the old bake element, they are either screwed on or cliped on with a spade terminal. Take the old bake element and new element and make sure they match. now put the wires on the new bake element and reinstall. Then you can turn the power back on and test.
Nov 19, 2009 | Magic Chef 9815 Electric Single Oven
I need a bake heating element for model number plt083-2, we can't find one and i would like to know what's compatible with it?
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with brand and model number and we will get a bake element for you.
We look forward to working with you. Thanks, Ella
Nov 15, 2009 | Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Nov 08, 2008 | Kitchen Ranges
Baking element
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Sep 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
