I have a cctv camera installed in my office i want to access it i don't know how to access it. someone says that there is a website 198.168.1.100 login
  • 114 Answers
Could be anything as IP address, like 192.168.xxx.xxx , so you need to talk to the IT guys. If this is not an option try to install this freeware "Advanced IP scanner" from http://www.snapfiles.com/freeware/network/fwscanner.html and run a scan. Hopefully you will see something like "CCTV" or "camera" next to an IP address. Then you can open a browser and type "http:// ipaddress you found" (example http://192.168.1.100).
Posted on Mar 16, 2011
    Problem Solver:
  • 6 Answers
You have only told about your internal ip.For remote viewing we have to know weather the net connection is static or dynamic.If static ip is there you can use it directly for remote viewing else you have to make use of ddns sites for this purpose
Posted on Apr 14, 2011
    Sergeant:
  • 146 Answers
If the address is 198.168.1.100 mean only can be access inside your network and not from outside unless it published on steaming media.
198.168.1.100 is local internet protocol addressing.
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
Can the exsisting protacal be modified?
Good question. What camera? Most cameras cannot be modified. Some newer cameras are multiple protocols. Need more information.
Sep 25, 2014 | CCTV Camera Pros MON-LCD35P Test Monitor...
What Are The Benefits Of A Wireless Cctv Camera?
The use of a wireless CCTV camera has its specific benefits. One is that the wireless CCTV systems can be used anywhere since there is no cabling required. They are also easy to install and are flexible. In addition, owing to the fact that there are no cables and that they are easy to install, wireless cameras also feature lower cost.
Apr 24, 2013 | Home Security
Reinstating a 7 camera system on a house. known to have been based on GV 800. hardware and software all installed with no error messages. only one camera actually displays a picture - the rest just say...
The geovison cards have quite a few issues with winXP and up because of the way they switch inputs. Windows don't seam to know how to handle it, i would try installing the drivers for the device again. You should see 4 video capture cards as well as a pci-bridge installed.
I also highly recommend Zoneminder for cctv. http://www.zoneminder.com/
Jul 04, 2011 | Geovision GV-800-16 Video Capture
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Where does a father of a three year old son turn to when the mother of his child is out of control?
i will install complete cctv cameras in your households,businesses,institutions. For an extra Ksh500 i will train your how to ride the smart wheel.
31441499430515vandal-resistant-cctv-dome-ugfzdd22zjr2335uzarn4ezi-3-2.jpg Online Jobs in Kenya
Online Jobs in Kenya Kenyan Jobs Five Sok 5 Sock Fiveso Five Sock 5Sok
Apr 19, 2010 | Alert Home Security
Cctv camera wire pulled off
a simple web search for "scart socket connections" will find details of what signals each pin of a scart connector carry. however, your problem is knowing what signals the wires from your cctv camera carry. only the camera manufacturer, or a service engineer familiar with it, can tell you that.
Aug 18, 2009 | Home Security
Can't access remotely my cctv. I have a dynamic ID address
it sounds like your router is setup for remote management. this means that when you type in the ip address the admin screens come up instead of the camera system. you need to turn off remote admin in the router and then configure port forwarding to reach your cameras
Jun 05, 2009 | Gateway Wireless-B Router (wbr-100)
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
