Question about HP ScanJet 5530 Flatbed Scanner
How does open it and show me the procedure to run scanner
The error show replace drum unit and developer but when i replace it with new drum unit and developer the error still shows drum unit and developer need to change?
you did not do it right first you run drum dry, then clear the counter then install the new drum and developer, now get new developer and drum and follow the service manual drum dry first then clear counters then run TCR adj. then run gradation procedure Better to get a tech to do it.
Aug 13, 2015 | Konica Minolta Bizhub 423 Copier Printer...
My dommino A300 industriel printer is showing a fault; it says Fall-back jet modulation in use, and I cannot find the problem and solve; I run of ideas, thank you for your halp
Check the scanner assembly if is running during printer initialization. If not open the assembly and check the scanner motor circuit if fault replace.
Dec 12, 2014 | Office Equipment & Supplies
Moved my M20i 20 feet now it won't copy or scan. Have done the Lock/Unlock of scanner. Worked before I moved it, but not now. Have upgraded the firmware and reset everything.
If you're using the PC to initialize the operation you want to do, and the USB cable is longer than 15 feet, then you will need to reduce the distance between the PC and the printer and use a shorter cable. USB cables should not be longer than 15 feet. Anything longer adds to data corruption and the printer refuses to work.
If you're using the on-printer dashboard to do the scanning/copying then it may happen that some wires came loose. See if the printer can print from the PC, to verify that the printing mechanism is OK. Then, turn off and back on the device and see if the scanner lights up and does the initial alignment. This should make some noise and move the scan head back and forward an inch or so (depending on the model). If the initialization of the scanner works that will mean there are no loose wires.
If the scanner does not go through the initialization procedure then probably some wires got loose inside and you'll need to open it and check the connections. If the scanner does initialize then you should run a self-diagnostic procedure from the printer dashboard. This should be a menu selection (usually in the Troubleshooting section). Check your users manual for the self-diagnostic procedure and how to run it.
Also, you may try to remove the toner/printing assembly and re insert it, just to jumpstart the diagnostic procedure that may then fix the problem by itself without throwing out any messages on the built in LCD.
Jan 13, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Unable to clean 46
Code 46 means that your absorbing pad is full, Brother recommends you see a technical engineer but heres a quick self help guide:
  1. Open your scanner lid and scanner bed.
  2. Remove the 5 screws from the front (2 large and 3 small)
  3. Unclip front panel from unit.
  4. Unclip and remove scanner unit from main base (be careful of wires/cables).
  5. See the printer guide that runs the head unit left to right, well on the right hand side you will see a small square black looking piece of sponge (this is your absorbing pad).
  6. Remove pad with tweezers and run under warm water untill water runs clear (do not squeeze pad).
  7. Leave wet pad somewhere to dry naturally for about 24-36hrs.
  8. Replace pad when dry and assemble printer by doing reverse procedure above.
sincerely
rover620
Sep 10, 2010 | Brother DCP-330C All-In-One InkJet Printer
Actullay, sir, i broughted this scanner systems about 10years old that time in pakistan win xp is not produce properly i have orignal cd of scanner but this driver the said cd valid for win98 and millinium...
How to make any Acer/BenQ/Vuego/Brisa parallel port scanner work in Windows XP (note: this procedure does not work in Windows 7 or Vista, only in XP):
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web: ftp://12.145.38.159/scanner/drivers/parallel/mirascanv3424p.zip
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on "EPPSCANNER" and where it says "Model" it should say "color flatbedscanner". Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: ftp://12.145.38.159/scanner/manuals/scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but the procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
Note: This solution does not work on all computers but many report success with it. The hang-up is caused from certain chipsets in the computer motherboard.
Sep 04, 2010 | Acer ScanPrisa 640P Flatbed Scanner
LOCK ALL CHANNEL
If all channels are showing the lockout icon, and all are displaying the frequency 000.0000, you just need to program the scanner. Entering a frequency will remove the lockout.
If all are showing lockout and programmed frequencies, and the scanner will not function, you need to initialize it. This procedure will erase all data that you have programmed into the scanner and restore it to original factory settings.
- Turn the scanner OFF, then power it ON again. "Multi-system Trunking Scanner" shows on the display.
- Press 0
- Press 1
- Press ENT
"Initializing please stand by" shows on the display for about 5 seconds.
Do not turn the scanner OFF until initializing is complete and the display shows "M000" on the top line and "Bank 0 Ch 0" on the third line.
Need more information on your scanner? You can download/print the operating manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-97 Handheld Scanner
Need to find a free download to install
Step 1. Download MiraScan v3.424 from the web : Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says Manufacturer and then click on EPPSCANNER and where it says Model it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
SOURCE : http://forums.driverguide.com/showthread.php?t=35623
Originally written by Jerry K 12-03-2007
Oct 13, 2009 | AcerScan Prisa 340P Flatbed Scanner
I need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p email: elfondkya_ihabmoh@yahoo.com
Instructions for installing Acer brand parallel port scanners in Windowsmag-glass_10x10.gif XP:
Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
scpinwxp-eng.pdf
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Mar 22, 2009 | AcerScan Prisa 620U Flatbed Scanner
Canoscan lide50 does not scan
Please follow these steps :-
1- try to scan the image in MS paint.
just open mspaint by the RUN command.
click on FILE and select FROM SCANNER AND CAMERA
then try to scan.
2- Try to restart the scanner service from the services.msc
type services.msc in RUN command.
restart the system.
or
try to restart the system in safe mode then try again to scan the document.
press F8 for safe mode while reboot the system.
3- Try to delete scanner from the DEVMGMT.MSC
just click on scanner in the list and delete that.
it can be in USB list.
restart the system
or
4- Try to uninstall scanner's driver from the DEVMGMT.MSC
just type DEVMGMT.MSC in RUN command
then select the scanner from the USB device and right click on the scanner and try to uninstall driver.
then install driver from the cd or internet.
Jan 21, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Error A1
This is no error! It indicates that the scanner is open (what you have done to replace the carts or when there is a paperjam).
It might be that the ph is clogged (mostly due to generic ink).
Run the manual cleaning procedure 3 times!
If there is no more bk /y you need a new ph.
Mar 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
HP ScanJet 5530 Flatbed Scanner Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
