Question about Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
  • 30 Answers
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Posted on Mar 16, 2011
Push button on microwave has stopped working
It is easy and cheap to fix this, but you need to know about electricity and electronics. Look for a local appliance repair person if you feel it is worth it, but many ovens are so cheap it may not be worth the repair costs.
Oct 09, 2014 | Baumatic BTM23 900 Watts Microwave Oven
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Gas rings will not light because of no electric spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Baumatic Microwave Ovens
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Jun 10, 2011 | Microwave Ovens
I have a qasair rangehood (uv-1200-2) with 2 lights. The lights have not worked for a year or so. I have now replaced them (following http://www.qasair.com.au/images/installation_inst/QAIInstr_Lamp.pdf )...
First, turn off power to the rangehood. Check the contact resistance of the light switch(es) with an ohmmeter. It should be less than 0.1 Ohms. If you get a substantially higher resistance in the on position, the switch contact is burned out. Also, inspect the wiring harness connector and the connections to the light fixtures. If they show signs of overheating, the connection resistance is too high. You can try polishing the connector contacts to remove oxidation. I use a pencil eraser for mild cases and a non-metallic dry scouring pad (3M Scotch-Brite) for more severely tarnished contacts. In the worst case it will be necessary to replace the terminals or connector.
According to the drawing for this series on the Qasair website, the unit uses fluorescent lamps rather than the halogen lamps referred to in the lamp installation instructions. If this is true, it is likely the ballast has failed (if the lamps have separate switches, they probably have separate ballasts also). If the original ballast model is no longer available, make sure the replacement has at least as high a maximum temperature rating as the original. This is especially critical for electronic ballasts. You can extend the life of the new ballasts by making sure the fans are running before turning on the lights - this should reduce the ambient operating temperature inside the hood.
May 25, 2011 | Microwave Ovens
How do we replace the light bulb in our Baumatic BTM25SS microwave oven? It seems to be inaccessible....
From Baumatic:
"Unfortunately, the bulb is positioned next to the main working component of
the microwave. This means only a qualified domestic appliance engineer,
trained to work with microwaves can carry out such a repair. If you wish to
have a Baumatic engineer attend, please contact the Baumatic Customer Care
team direct on 0118 933 6911. If, however, you wish to purchase the correct
bulb and have a local engineer carry out the repair, please call the
baumatic Spares team direct on 01235 437 244 for price and delivery
information."
Nov 20, 2010 | Baumatic BTM25SS Convection Microwave Oven
How to replace bulb in baumatic btm25ss microwave oven?
Had the same problem. From Baumatic:
baumatic Spares team direct on 01235 437 244 for price and delivery"
information.
Apr 17, 2009 | Baumatic BTM25SS Convection Microwave Oven
Kenmore 63682300 Bulb blew now lights won't turn off
See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
276 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
