My dimpex electri heater model 6902340100 suddenlt died. Is there a reset or a fuse to restore it to use? The main on off switched seemed to freeze in one position then the unit stopped working.
    Brigadier General:
  • 4,736 Answers
It just may need resetting. If you can, turn OFF the Master Control Switch and unplug the heater. Leave unplugged for 12 to 15 minutes. Plug the heater back in and turn the Master On/Off Switch to ON. If everything works as normal, then the heater successfully reset itself. If this continues to be an issue, unplug the heater and call Dimplex USA, Technical Service 888-346-7539.
Hope this helps to solve your problem. Please be kind enough to let me know.
Posted on Mar 16, 2011
Kia optima hybrid 2012 not electrial function at all, the car is no working no ligths,not ignition complete dead what I need to do?
Did you replace the battery recently?
seem like your main fuse many may be 100 or 120amp fuse is blown and not powering little fuses.
Feb 18, 2017 | Kia Optima Cars & Trucks
How do I reset my Comfort Zone Heater Model CZ20118
no sign of power ===main power line or power switch may be defective,,,if u want to reset===power offf main power & wait for tan minutes
Feb 20, 2015 | Comfort Zone Heating & Cooling
I have an Electrolux Washer Dryer EWX14440W - the missus loves it but today it stopped working completely (no power). I have checked there is power getting to the machine's cable and the fuse on the
inside the machine youll find a 10 amp fuse
DONT just replace it
find out why it died perhaps a bad pump
however if it has earth leakage then you would find your mains box trips would break
depends on your house lecky if you have fuses or breakers
to kill the mains 10 amp is bad
so if its a mains fail then
think that if you have mains throw thru current leakage
then it must be a short in the mains
too blow the fuses this takes more than 10 amps
and not water stuff to earth
i think some machines have resetable fuses
inside a flap on the back
i also think your machine is full of oose and blockage
three faults at once crap crub and crust in pumps and air flows heaters etc have caused it too over heat
you may also need to reset the popup fuses on the tumble heater section
Oct 01, 2014 | Washing Machines
Where do i find fuses on an electric heater
No make or model. I have found most of the heaters I have disassembled to have resetable circut breakers. One of the failure points is the temperature limit switches. A little round disk that has two wires going to it that stops the electri when a temperature is reached or exceeded. These are AC circuits so use caution.
Apr 23, 2014 | Heating & Cooling
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Not usin tablet, finnishin cycle and heatin water
This is an electrial issue.
If you are uncomfortable working with electricity get a pro.
If the power to the heater does have some sort of temp control. That may be the issue. It heats till the Thermo switch opens. Sometimes they fail.
Mar 24, 2010 | Dishwashers
Heater floor door dosnt open is it vacuam or electrial and how do i fix it 2000 gmc jimmy
With the key in the off position; remove the RDO BAT fuse for at least 10 seconds then replace the fuse; turn on or start the vehicle and try the A/C again. Removing the fuse should reset blend actuators.
Jan 09, 2010 | 2000 GMC Jimmy
Turn on key no electrial, no lights no nothing, battery is full charge checked all the fuses in side panel, all good Is there a reset button or somthing like that.. Or a master fuse?
Hi and welcome to FixYa,
There is a master fuse. It is 30 amps and is located at the side of the starter motor relay. To determine the location of this relay, follow the wire from the + terminal of the battery. The main fuse is responsible for supplying all the electrical power of the bike except for the starter itself.
Good luck and thank you for using FixYa
Apr 08, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
STACK DRYER DIED
heater box main fuse?is it turning inside and belt turning?-mike
Oct 26, 2008 | Dryers
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
