Question about Toshiba E-studio 281c Copier
I have a Toshibia Studio 281C, I am running windows 7 and cannot print in color. 2 other machines in my office (both running XP) can print in color fine. This leads me to believe this might be a driver issue. does anyone know of the correct driver to download for this problem?
  • Toshiba Master
  • 643 Answers
Kindly download & install the latest printer driver that support Window 7.
http://www.eid.toshiba.com/support/index.jsp
Posted on Mar 30, 2011
  • Brenda Hendrick
    Brenda Hendrick Apr 02, 2014
    Im having same issue, but which driver do I need to install there are several listed
My Toshiba 282 printer don't pint but the print data light green,when i issue command
U need to make sure the printer kit is installed, otherwise printing will not work. The printer kit is like a usb dongle, plugged on the usb port along with network port
Nov 28, 2015 | Toshiba E-studio 281c Copier
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
How to reboot the machine?
first do 0+8 tush and switch do on after do 690 tush after print switch after 2 after interup
Aug 03, 2014 | Toshiba E-studio 281c Copier
Cant print in color with e studio 281c I can copy in color
The 281c can be set to print to black only as a cost saving measure. The printer control panel is accessed through your browser (using the IP address of the printer) and the setting is made there. You should be able to override this through the printer properties in windows, but I have found that the PCL5 driver worked to switch between B/W and colour, while the PCL6 driver did not. So, for me the easy solution was to install the PCL5 driver and use that.
Apr 02, 2014 | Toshiba E-studio 281c Copier
Color print
turn the Revolving Developer Unit which is on your left side when you open the front cover, turn it manually clockwise unit red color comes out, then release the lever gently pullout the cartridge.
Nov 14, 2013 | Toshiba E-studio 281c Copier
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
My toshiba e studio 281c will not print in colour it will only copy in colour
Your print driver is probably set to monochrome. Usually there are to drivers set up on your computer: a pcl5 for black/white, and a ps3 for color--or vice-versa. Right click your driver; you can change the setting in your preference or properties section.
Oct 16, 2012 | Toshiba E-studio 281c Copier
Will hallmark card studio 8 work on windows 7
you are going to run on windows 7 since hallmark card studio 8 needs systems configuration such as Windows XP or Vista, Pentium III 500 MHz, 600MB of hard disk space, 2GB for full install,16-bit color, and color printer.
So have fine work!
Dec 21, 2009 | Creative Home Hallmark Card Studio Deluxe...
Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Jun 02, 2008 | Toshiba Estudio 200L Copier
Toshiba E-studio 281c Copier Logo
989 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
