Question about Lexmark Wheelwriter 1500 Typewriter
I want to remove the "Chirpy" sound on the return after typing.
  • Lexmark Master
  • 3,594 Answers
Get some WD40, spray a little on the silver shaft that the carrier slides on. If that doesn't do it you have to lube the carrier motor. It is located in the R. rear corner under the case. The front one can be reached from the inside of the T/W the back one you must remove the case or fish the straw thru the case.
DickyO
Posted on Mar 16, 2011
How to reverse the scroll button?
Step 1: Install AutoHotkey on your Windows PC.
Step 2: Launch AutoHotkey, and when prompted to create a sample script, click the Yes button. Step 3: When the sample script appears in Notepad, paste the following code just below the two sample hotkeys:
WheelUp::
Send {WheelDown}
Return
WheelDown::
Send {WheelUp}
ReturnStep 4: Save the script in Notepad (Ctrl+S). That's it. Now scrolling on your Windows touch pad or mouse will be reversed. To enable the script on reboot, just copy the AutoHotkey shortcut to your Startup folder. If you end up using AutoHotkey for other scripts, just copy the shortcuts to the scripts themselves into the Startup folder. To disable reverse scrolling, edit the code out of the script or uninstall AutoHotkey entirely.
(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]''function(){(i[r].q=i[r].q''[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)})(window,document,'script','https://www.google-analytics.com/analytics.js','ga');body{margin:0;padding:0;overflow:hidden;line-height:0;}(function(){var b=this;var h=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,d){return ad?1:0};var n;a:{var p=b.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,d){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=d(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=b.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var d=0,c=h(String(E)).split("."),e=h(String(a)).split("."),k=Math.max(c.length,e.length),l=0;0==d&&le)c=a+"&nm="+c;else var e=e+4,k=a.indexOf("&",e),c=0 0) {var c = a.href.substring(0, bi+6); var d = a.href.substring(bi+6, a.href.length);var ei = d.indexOf("&");var r = '';if (ei >= 0)r = d.substring(ei, d.length);a.href = c + t + r; } else {a.href += "&clkt=" + t;}}}(function(){var c=this;var g=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,b){return ab?1:0};var n;a:{var p=c.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var d=r;Object.prototype.hasOwnProperty.call(d,a)''(d[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=c.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,d=g(String(E)).split("."),h=g(String(a)).split("."),k=Math.max(d.length,h.length),l=0;0==b&&lb''parseInt(b,10)!==b)b=17;L(a,b)};window.cll=function(a,b){L(a,b''1)};window.clb=function(a){L(a,2)};window.clh=function(a,b){L(a,b''0)};}).call(this);(function(){var d=this;var k=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,b){return ab?1:0};var n;a:{var p=d.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=d.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,c=k(String(E)).split("."),e=k(String(a)).split("."),f=Math.max(c.length,e.length),l=0;0==b&&lc?e=b+f+e:(c+=f.length,f=b.indexOf("&",c),e=0b?1:0};var n;a:{var p=d.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=d.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,c=h(String(E)).split("."),e=h(String(a)).split("."),k=Math.max(c.length,e.length),l=0;0==b&&le)c=b+"&mb="+c;else{var e=e+4,k=b.indexOf("&",e);c=0c?1:0};var m;a:{var n=b.navigator;if(n){var p=n.userAgent;if(p){m=p;break a}}m=""};var r=function(a,c){var f=q;Object.prototype.hasOwnProperty.call(f,a)''(f[a]=c(a))};var t=-1!=m.indexOf("Opera"),u=-1!=m.indexOf("Trident")''-1!=m.indexOf("MSIE"),v=-1!=m.indexOf("Edge"),w=-1!=m.indexOf("Gecko")&&!(-1!=m.toLowerCase().indexOf("webkit")&&-1==m.indexOf("Edge"))&&!(-1!=m.indexOf("Trident")''-1!=m.indexOf("MSIE"))&&-1==m.indexOf("Edge"),x=-1!=m.toLowerCase().indexOf("webkit")&&-1==m.indexOf("Edge"),y=function(){var a=b.document;return a?a.documentMode:void 0},z;a:{var A="",B=function(){var a=m;if(w)return/rv\:([^\);]+)(\)';)/.exec(a);if(v)return/Edge\/([\d\.]+)/.exec(a);if(u)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(x)return/WebKit\/(\S+)/.exec(a);if(t)return/(?:Version)[ \/]?(\S+)/.exec(a)}();B&&(A=B?B[1]:"");if(u){var C=y();if(null!=C&&C>parseFloat(A)){z=String(C);break a}}z=A}var D=z,q={},E=function(a){r(a,function(){for(var c=0,f=h(String(D)).split("."),g=h(String(a)).split("."),N=Math.max(f.length,g.length),k=0;0==c&&kvar adData = {google_width: 300,google_height: 250,google_click_url: 'https://www.googleadservices.com/pagead/aclk?sa\x3dL\x26ai\x3dCLmN7sErtV-6UA9OznASF5JzICaPP9uxGgfr01-EBvbjUkgEQASDMka4iYMnWzYqspLQUoAHDitD9A8gBCeACAKgDAcgDmwSqBMgBT9BjimtOmU-32dP8-f3uYkR56LkCvg1CTC0LVEp8L_R1zTcbQ_DU233JeXwTZeybnBdZuTBjZinEMxyTrKOz3Z3ctxUHodsUV0T-pjHlolVLgPhqZoLEl5wnqCVzVscOpSw1GkGLJIflRpHOph5T3TnDPYBjuSBkBwU6wmlmfpJL5QmcNME21x_DfiZMiw8K-d4V87YHlqOlOj6Y4Zm_a4IHf4V7sJdPZVQIqM_hyj8VdUZWtTUVuG6Z1brwLjOZwjbcU6YRLmzgBAGIBgGgBi6AB6X1rwKoB4HGG6gHpr4b2AcA0ggFCIBhEAE\x26num\x3d1\x26cid\x3dCAASEuRoYGJ8gviuaMdSC1q9lAGtgQ\x26sig\x3dAOD64_1HKPu3cDi1CWLurJRneBWwoatu5g\x26client\x3dca-pub-1991679624331369\x26adurl\x3d',google_ait_url: '',redirect_url: 'https://www.googleadservices.com/pagead/aclk?sa\x3dL\x26ai\x3dCLmN7sErtV-6UA9OznASF5JzICaPP9uxGgfr01-EBvbjUkgEQASDMka4iYMnWzYqspLQUoAHDitD9A8gBCeACAKgDAcgDmwSqBMgBT9BjimtOmU-32dP8-f3uYkR56LkCvg1CTC0LVEp8L_R1zTcbQ_DU233JeXwTZeybnBdZuTBjZinEMxyTrKOz3Z3ctxUHodsUV0T-pjHlolVLgPhqZoLEl5wnqCVzVscOpSw1GkGLJIflRpHOph5T3TnDPYBjuSBkBwU6wmlmfpJL5QmcNME21x_DfiZMiw8K-d4V87YHlqOlOj6Y4Zm_a4IHf4V7sJdPZVQIqM_hyj8VdUZWtTUVuG6Z1brwLjOZwjbcU6YRLmzgBAGIBgGgBi6AB6X1rwKoB4HGG6gHpr4b2AcA0ggFCIBhEAE\x26num\x3d1\x26cid\x3dCAASEuRoYGJ8gviuaMdSC1q9lAGtgQ\x26sig\x3dAOD64_1HKPu3cDi1CWLurJRneBWwoatu5g\x26client\x3dca-pub-1991679624331369\x26adurl\x3dhttp://www.flir.com/instruments/sim/%3Fpi_ad_id%3D60526290145',visible_url: 'flir.com/Thermal-Simulator',destination_url: 'http://www.flir.com/instruments/sim/?pi_ad_id\x3d60526290145',link_target: '_blank',google_template_data: {rendering_settings: {'format': '300x250','bgSignal': 'true','enableRtl': 'true'},'adData': [{'templateId': '2035','text1TFText': 'FLIR® Infrared Cameras','text2TFText': 'Take An IR Camera For A Virtual Test Drive. See What You\x27re Missing','displayUrl': 'flir.com/Thermal-Simulator','clickTFText': 'Visit Site','product1MCImage': 'https://tpc.googlesyndication.com/daca_images/simgad/9322235502109855307','product1MCImageWidth': '128','product1MCImageHeight': '128','logoBackColor': '#FFFFFF','textBackDarkColor': '#1A237E','textBackLightColor': '#3F51B5','logoColorType': '1','accentColor': '#1F3E7D','mainColor': '#FFFFFF','layout': 'scream_logo_eta_all_sizes','siriusFlagEnableClickParams': 'true','siriusFlagBorderColor': '#E0E0E0','FLAG_client_side_flag_overrides': '[{\x22name\x22 : \x22uses_octagon_sdk\x22, \x22value\x22 : true}]','gpaFlagNoBorder': 'false','versionInfo': '7.3.2'}]}};window.ExitApi = undefined; if (window.onAdData) {onAdData(adData, window.ExitApi);}div,ul,li{margin:0;padding:0;}.abgc{height:15px;position:absolute;right:16px;top:0px;text-rendering:geometricPrecision;width:15px;z-index:9020;}.abgb{height:15px;width:15px;}.abgc img{display:block;}.abgc svg{display:block;}.abgs{display:none;height:100%;}.abgl{text-decoration:none;}.abgi{fill-opacity:1.0;fill:#00aecd;stroke:none;}.abgbg{fill-opacity:1.0;fill:#cdcccc;stroke:none;}.abgtxt{fill:black;font-family:'Arial';font-size:100px;overflow:visible;stroke:none;} var abgp={elp:document.getElementById('abgcp'),el:document.getElementById('abgc'),ael:document.getElementById('abgs'),iel:document.getElementById('abgb'),hw:15,sw:75,hh:15,sh:15,himg:'https://tpc.googlesyndication.com'+'/pagead/images/adchoices/icon.png',simg:'https://tpc.googlesyndication.com/pagead/images/adchoices/en.png',alt:'AdChoices',t:'AdChoices',tw:53,t2:'',t2w:0,tbo:0,att:'adchoices',ff:'',halign:'right',fe:false,iba:false,lttp:false,umd:false,uic:false,uit:false,ict:document.getElementById('cbb'),icd:undefined,uaal:true,opi: false};.cbc{background-image: url('https://tpc.googlesyndication.com/pagead/images/x_button_blue2.svg');background-position: right top;background-repeat: no-repeat;cursor:pointer;height:15px;right:0;top:0;margin:0;overflow:hidden;padding:0;position:absolute;transform: scaleX(1);width:16px;z-index:9010;}.cbc.cbc-hover {background-image: url('https://tpc.googlesyndication.com/pagead/images/x_button_dark.svg');}.cbc > .cb-x{height: 15px;position:absolute;width: 16px;right:0;top:0;}.cb-x > .cb-x-svg{background-color: lightgray;position:absolute;}.cbc.cbc-hover > .cb-x > .cb-x-svg{background-color: #58585a;}.cb-x > .cb-x-svg > .cb-x-svg-path{fill : #00aecd;}.cbc.cbc-hover > .cb-x > .cb-x-svg > .cb-x-svg-path{fill : white;}.cb-x > .cb-x-svg > .cb-x-svg-s-path{fill : white;}
.ddmc{background:#ccc;color:#000;padding:0;position:absolute;z-index:9020;max-width:100%;box-shadow:2px 2px 3px #aaaaaa;}.ddmc.left{margin-right:0;left:0px;}.ddmc.right{margin-left:0;right:0px;}.ddmc.top{bottom:20px;}.ddmc.bottom{top:20px;}.ddmc .tip{border-left:4px solid transparent;border-right:4px solid transparent;height:0;position:absolute;width:0;font-size:0;line-height:0;}.ddmc.bottom .tip{border-bottom:4px solid #ccc;top:-4px;}.ddmc.top .tip{border-top:4px solid #ccc;bottom:-4px;}.ddmc.right .tip{right:3px;}.ddmc.left .tip{left:3px;}.ddmc .dropdown-content{display:block;}.dropdown-content{display:none;border-collapse:collapse;}.dropdown-item{font:12px Arial,sans-serif;cursor:pointer;padding:3px 7px;vertical-align:middle;}.dropdown-item-hover, a.dropdown-item.dropdown-item-hover {background:#58585a;color:#fff;}.dropdown-content > table{border-collapse:collapse;border-spacing:0;}.dropdown-content > table > tbody > tr > td{padding:0;}a.dropdown-item {color: inherit;cursor: inherit;display: block;text-decoration: inherit;} Ad covers the page Report this ad (function(){var k=this,l=function(a,b){var c=a.split("."),d=k;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var f;c.length&&(f=c.shift());)c.length''void 0===b?d=d[f]?d[f]:d[f]={}:d[f]=b},ba=function(a,b,c){return a.call.apply(a.bind,arguments)},ca=function(a,b,c){if(!a)throw Error();if(2c.indexOf(b))){for(var c=c.split(/\s+/),d=0;db?1:0};var x;a:{var y=k.navigator;if(y){var z=y.userAgent;if(z){x=z;break a}}x=""};var ea=function(a,b){var c=da;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var fa=-1!=x.indexOf("Opera"),A=-1!=x.indexOf("Trident")''-1!=x.indexOf("MSIE"),ga=-1!=x.indexOf("Edge"),B=-1!=x.indexOf("Gecko")&&!(-1!=x.toLowerCase().indexOf("webkit")&&-1==x.indexOf("Edge"))&&!(-1!=x.indexOf("Trident")''-1!=x.indexOf("MSIE"))&&-1==x.indexOf("Edge"),ha=-1!=x.toLowerCase().indexOf("webkit")&&-1==x.indexOf("Edge"),C=function(){var a=k.document;return a?a.documentMode:void 0},D;a:{var E="",F=function(){var a=x;if(B)return/rv\:([^\);]+)(\)';)/.exec(a);if(ga)return/Edge\/([\d\.]+)/.exec(a);if(A)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(ha)return/WebKit\/(\S+)/.exec(a);if(fa)return/(?:Version)[ \/]?(\S+)/.exec(a)}();F&&(E=F?F[1]:"");if(A){var G=C();if(null!=G&&G>parseFloat(E)){D=String(G);break a}}D=E}var H=D,da={},I=function(a){ea(a,function(){for(var b=0,c=t(String(H)).split("."),d=t(String(a)).split("."),f=Math.max(c.length,d.length),e=0;0==b&&e.feedback_container {width: 100%;height: 100%;position: absolute;top:0;left:0;display: none;z-index: 9020;background-color: white;}.feedback_page {font-family: "Arial";font-size: 13px;margin: 16px 16px 16px 16px;}.feedback_title {font-weight: bold;color: #000000;}.feedback_page a {font-weight: normal;color: #3366cc;}.feedback_description {color: #666666;line-height: 16px;margin: 12px 0 12px 0;}.feedback_closing {color: #0367ff;line-height: 16px;margin: 12px 0 12px 0;}.feedback_logo {position: absolute;right: 0;bottom: 0;margin: 0 12px 9px 0;}.feedback_logo img {height: 15px;}.survey_description {color: #666666;line-height: 17px;margin: 12px 0 10px 0;}.survey {color: #666666;line-height: 20px;}.survey_option input {margin: 0;vertical-align: middle;}.survey_option_text {margin: 0 0 0 5px;line-height: 17px;vertical-align: bottom;}.survey_option:hover {background-color: lightblue;cursor: default;} Thanks for the feedback! Undo
What was wrong with this ad?
InappropriateRepetitiveIrrelevant Thanks for the feedback! Back
We'll review this ad to improve the experience in the future.
We'll use your feedback to review ads on this site.
Closing ad: %1$d (function(){var k,l=this,m=function(a,b){var c=a.split("."),d=l;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var e;c.length&&(e=c.shift());)c.length''void 0===b?d=d[e]?d[e]:d[e]={}:d[e]=b},n=function(a){var b=typeof a;if("object"==b)if(a){if(a instanceof Array)return"array";if(a instanceof Object)return b;var c=Object.prototype.toString.call(a);if("[object Window]"==c)return"object";if("[object Array]"==c''"number"==typeof a.length&&"undefined"!=typeof a.splice&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("splice"))return"array";if("[object Function]"==c''"undefined"!=typeof a.call&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("call"))return"function"}else return"null";else if("function"==b&&"undefined"==typeof a.call)return"object";return b},aa=function(a){var b=n(a);return"array"==b''"object"==b&&"number"==typeof a.length},p=function(a){return"string"==typeof a},q=function(a){var b=typeof a;return"object"==b&&null!=a''"function"==b},ba=function(a,b,c){return a.call.apply(a.bind,arguments)},ca=function(a,b,c){if(!a)throw Error();if(2b?1:0};var da=Array.prototype.indexOf?function(a,b,c){return Array.prototype.indexOf.call(a,b,c)}:function(a,b,c){c=null==c?0:0>c?Math.max(0,a.length+c):c;if(p(a))return p(b)&&1==b.length?a.indexOf(b,c):-1;for(;cparseFloat(G)){E=String(I);break a}}E=G}var J=E,ga={},K=function(a){return ha(a,function(){for(var b=0,c=v(String(J)).split("."),d=v(String(a)).split("."),e=Math.max(c.length,d.length),f=0;0==b&&f=this.boundingClientRect.bottom&&this.boundingClientRect.left>=this.boundingClientRect.right)},Fa=function(){var a=new Ea;return a.N&&(!a.Y''a.O>=a.X)};var V=function(a,b){this.F=a;this.m=0;this.j=document.getElementById("mtadmas");this.L=document.getElementById("mtadmaundo");this.B=document.getElementById("mtadmac");this.C=document.getElementById("mtadmback");this.I=document.getElementById("mtadmpc");this.M=document.getElementById("mtadmpundo");this.w=document.getElementById("mtadmpunclose");this.K=this.u=this.G=this.D=null;this.v=0;this.h=null;this.i=!1;this.s=null;this.T=b?b.getAdsLength():1;(this.g=b)&&this.g.registerWidget(this,0);this.H=0},Ga=function(a,b){for(var c=[],d=b;d&&"BODY"!=d.tagName;d=d.parentNode)d.style&&"block"!=d.style.display&&(c.push({el:d,val:d.style.display}),d.style.display="block");for(var d=a(b),e;e=c.pop();)void 0!==e.W&&(e.Z.style.display=e.W);return d},Ha=function(a){for(var b=document.getElementsByName("surveyOptions"),c=0;ce''e>g''a.h)){var h=sa();c=r(function(){var a="";g=g&&Y(this);g--},a);c();0parseFloat(F)){E=String(H);break a}}E=F}var I=E,w={},J=function(a){x(a,function(){for(var b=0,c=p(String(I)).split("."),d=p(String(a)).split("."),r=Math.max(c.length,d.length),h=0;0==b&&hthis.D&&(this.i=-1,U(this,1,a),null!==this.g&&(this.g.registerFinalizeCallback(m(this.g.fireOnObject,this.g,"attempt_survey_trigger",["wfocus",this.C,this.B,this.l,this.w,this.s,a])),5E3 (function(){var l=this,aa=function(){},ba=function(a){var b=typeof a;if("object"==b)if(a){if(a instanceof Array)return"array";if(a instanceof Object)return b;var c=Object.prototype.toString.call(a);if("[object Window]"==c)return"object";if("[object Array]"==c''"number"==typeof a.length&&"undefined"!=typeof a.splice&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("splice"))return"array";if("[object Function]"==c''"undefined"!=typeof a.call&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("call"))return"function"}else return"null";else if("function"==b&&"undefined"==typeof a.call)return"object";return b},m=function(a){return"string"==typeof a},ca=function(a,b){var c=Array.prototype.slice.call(arguments,1);return function(){var b=c.slice();b.push.apply(b,arguments);return a.apply(this,b)}},p=Date.now''function(){return+new Date},q=function(a,b){var c=a.split("."),d=l;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var e;c.length&&(e=c.shift());)c.length''void 0===b?d=d[e]?d[e]:d[e]={}:d[e]=b};var da=function(a,b,c,d,e){if(e)c=a+("&"+b+"="+c);else{var f="&"+b+"=",g=a.indexOf(f);0>g?c=a+f+c:(g+=f.length,f=a.indexOf("&",g),c=0e?c[1]="?":e==d.length-1&&(c[1]=void 0)}return c.join("")};var la=Array.prototype.indexOf?function(a,b,c){return Array.prototype.indexOf.call(a,b,c)}:function(a,b,c){c=null==c?0:0>c?Math.max(0,a.length+c):c;if(m(a))return m(b)&&1==b.length?a.indexOf(b,c):-1;for(;cb?null:m(a)?a.charAt(b):a[b]]''""}var b=u;if(wa())return xa(b);var b=va(b),c={};ma(b,function(a){c[a[0]]=a[1]});var d=ca(pa,c);return v("Opera")?a(["Version","Opera"]):v("Edge")?a(["Edge"]):w()?a(["Chrome","CriOS"]):(b=b[2])&&b[1]''""},xa=function(a){var b=/rv: *([\d\.]*)/.exec(a);if(b&&b[1])return b[1];var b="",c=/MSIE +([\d\.]+)/.exec(a);if(c&&c[1])if(a=/Trident\/(\d.\d)/.exec(a),"7.0"==c[1])if(a&&a[1])switch(a[1]){case "4.0":b="8.0";break;case "5.0":b="9.0";break;case "6.0":b="10.0";break;case "7.0":b="11.0"}else b="7.0";else b=c[1];return b};var za=function(a){za[" "](a);return a};za[" "]=aa;var Ba=function(a,b){var c=Aa;return Object.prototype.hasOwnProperty.call(c,a)?c[a]:c[a]=b(a)};var Ca=function(a,b){for(var c in a)Object.prototype.hasOwnProperty.call(a,c)&&b.call(void 0,a[c],c,a)},Ea=function(){var a=Da;if(!a)return"";var b=/.*[&#?]google_debug(=[^&]*)?(&.*)?$/;try{var c=b.exec(decodeURIComponent(a));if(c)return c[1]&&1e)return"";a.c.sort(function(a,b){return a-b});d=null;c="";for(var f=0;f=n.length){e-=n.length;b+=n;c=a.g;break}else a.l&&(c=e,n[c-1]==a.g&&--c,b+=n.substr(0,c),c=a.g,e=0);d=null==d?g:d}}f="";a.h&&null!=d&&(f=c+a.h+"="+(a.P''d));return b+f+""},Ka=function(a){if(!a.h)return a.o;var b=1,c;for(c in a.f)b=c.length>b?c.length:b;return a.o-a.h.length-b-a.g.length-1},La=function(a,b,c,d,e){var f=[];Ca(a,function(a,h){var g=Na(a,b,c,d,e);g&&f.push(h+"="+g)});return f.join(b)},Na=function(a,b,c,d,e){if(null==a)return"";b=b''"&";c=c''",$";"string"==typeof c&&(c=c.split(""));if(a instanceof Array){if(d=d''0,de?encodeURIComponent(La(a,b,c,d,e+1)):"...";return encodeURIComponent(String(a))};var Oa=function(a,b,c,d,e){if((d?a.O:Math.random())b;){try{if(c.google_osd_static_frame)return c}catch(e){}try{if(c.aswift_0&&(!a''c.aswift_0.google_osd_static_frame))return c.aswift_0}catch(e){}b++;c=c!=c.parent?c.parent:null}return null},vb=function(a,b,c,d,e,f,g){f=g''aa;if(10=e)){var f=Number(c[d].substr(0,e)),e=c[d].substr(e+1);switch(f){case 5:case 8:case 11:case 15:case 16:case 18:e="true"==e;break;case 4:case 7:case 6:case 14:case 20:case 21:case 22:case 23:case 24:case 25:e=Number(e);break;case 3:case 19:if("function"==ba(decodeURIComponent))try{e=decodeURIComponent(e)}catch(h){throw Error("Error: URI malformed: "+e);}break;case 17:e=na(decodeURIComponent(e).split(","),Number)}b[f]=e}}b=b[0]?b:null}else b=null;if(b&&(c=new M(b[4],b[12]),N&&N.match(c))){for(c=0;cW&&!T&&2==Y&&pc(t,"osd2","hs="+W)},rc=function(){var a={};qb(N,a);a[0]="goog_dom_content_loaded";var b=sb(a);try{pb(function(){wb(b)},10,"osd_listener::ldcl_int")}catch(c){}},sc=function(){var a={};qb(N,a);a[0]="goog_creative_loaded";var b=sb(a);pb(function(){wb(b)},10,"osd_listener::lcel_int");dc=!0},tc=function(a){if(m(a)){a=a.split("&");for(var b=a.length-1;0osdlfm(-1,'','BBMfmsErtV-6UA9OznASF5JzICQCB-vTX4QEAABABOAHIAQngAgDIA5sE4AQBoAYuwhMYChAQme-Z_QciCAgCEAEYASAAGMOK0P0D','',1804538184,true,'ocy\x3d1\x26ud\x3d1\x26la\x3d0\x26',3,'CAASFeRoYGJ8gviuaMdSC1q9lAGtgeOdCQ','//pagead2.googlesyndication.com/activeview?avi\x3dBBMfmsErtV-6UA9OznASF5JzICQCB-vTX4QEAABABOAHIAQngAgDIA5sE4AQBoAYuwhMYChAQme-Z_QciCAgCEAEYASAAGMOK0P0D\x26cid\x3dCAASFeRoYGJ8gviuaMdSC1q9lAGtgeOdCQ');if (window.top && window.top.postMessage) {window.top.postMessage('{"googMsgType":"adpnt"}','*');}{"uid":3,"hostPeerName":"https://www.cnet.com","initialGeometry":"{\"windowCoords_t\":0,\"windowCoords_r\":1280,\"windowCoords_b\":984,\"windowCoords_l\":0,\"frameCoords_t\":1002,\"frameCoords_r\":1216.5,\"frameCoords_b\":1252,\"frameCoords_l\":916.5,\"styleZIndex\":\"auto\",\"allowedExpansion_t\":0,\"allowedExpansion_r\":0,\"allowedExpansion_b\":0,\"allowedExpansion_l\":0,\"xInView\":0,\"yInView\":0}","permissions":"{\"expandByOverlay\":false,\"expandByPush\":false,\"readCookie\":false,\"writeCookie\":false}","metadata":"{\"shared\":{\"sf_ver\":\"1-0-4\",\"ck_on\":1,\"flash_ver\":\"23.0.0\"}}","reportCreativeGeometry":false,"isDifferentSourceWindow":false}" scrolling="no" marginwidth="0" marginheight="0" width="300" height="250" data-is-safeframe="true" style="border-width: 0px; border-style: initial; vertical-align: bottom;"> Step 5: Right-click on the AutoHotkey icon from the taskbar and select Reload This Script.
Sep 29, 2016 | Computers & Internet
Tip
How to Remove Check disk on every restart
Whenever the computer reboots the computer perform a check disk to find if there is any errors on the volume.
Instructions Things You'll Need:
  • Windows xp
  1. Step 1 Click on your start menu and open the run dialog.
  2. Step 2 Type "cmd" and return (note: don't enter quotes)
  3. Step 3 Next type "fsutil dirty query X:"( If it's your C: drive you should move the virtual memory to another drive).
    Where X :- is the Drive icon name
  4. Step 4 If the return message indicates that the volume is dirty go to step 5
  5. Step 5 Next type "chkdsk e: /f /x"
  6. Step 6 After that finshes repeat step 3.
  7. Step 7 If it is no longer dirty then reboot and you should notice no more
    CHKDSK.
on Feb 18, 2010 | Computers & Internet
GE Profiel model TPX24PBBE; getting "DE" fault. Can reset with "system check" and "cubed ice" buttons but problems return in a few days.
this code means the unit has not defrosted in the last 48 hours and may indicate a defective defrost timer or associated defrost components,try removing the toe-kick panel at the floor in front of the refrigerator,in there will be a small 2" X 2" box with 4 wires on a connector going to it,turn it until you hear a click and the fans stop,it will then be in defrost cycle,then look inside freezer and see if you see orange glow from defrost heater element and hear popping and sizzling sounds from ice melting and hitting element
Dec 23, 2012 | Refrigerators
I have an HP Pavilion dv 7 notebook pc. not sure why... in the middle of my screen a bar shows up with the word "volume" and a sound bar indicating that volume is twitching between 35% and 50%...
no photos , no joy
why post this lacking that,
remove all USB devices first. see if that cures it.
is the device manager showing errors on the onboard, sound chip>
my be bad keys for sound controls, (switches)
the hot keys are function keys on mine, see them>?
on mine if the hot keys strip is bad or the software to it drivers
bad to sound or the HP key strip (see the vol, updown buttons?) has bad driver there, it will mess up.
why not get a tech to fix this?
May 29, 2017 | HP DV9626US Pavilion Notebook
Internal speaker stopped working on my ipod 5th gen, headphones still work tho.... anyone got the solution??? cheers
Well, the internal speaker does not play sounds... It is not possible for the iPod's internal speaker to play music, as it is only capable of making three disctinct sounds:
the clicky noise
the alarm sound
the chirpy noise when you boot into diagnostic mode
You can get those sounds back by going into SETTINGS on the IPOD and turning the sounds back on.
Sep 09, 2010 | Apple iPod nano 5th Generation
Weird noises when it's on and zoom button noise picked up on vid
change auto focus to single focus mode,
since it is on continuous auto focus on default, it would focus all the time so you don't need to click half way before taking a picture
Mar 22, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Double chirp when trying to lock car from fob or key ? doors and boot all shut, why will it not set alarm and lock ?
this happened to my jag and i still havent managed to cure it ,its a computer fault i know but it will no doubt cost more to buy a new computer than the car is worth and it happened at the same time as one of the blower fans packed up,i rewired both in the end but the alarm still doesnt work or make the chirpy bleep that indicates that it has locked and set the alarm.
Jul 09, 2009 | 2004 Jaguar X-Type
How to write a code of a combobox
Try this code:
Combo-BOX - Abstraction With function you can retrieve the combo-box
structure with its data
<?php
function GetCombo_Where($db, $nombre, $tabla, $campo_lista, $campo_graba,
$campo_seleccionado,$valor_seleccionado,$where)
$query="SELECT * FROM $tabla ";
$query.=($where)?"WHERE ".$where:"";
$db -> query ($query);
$cant_registros = $db -> num_rows ( );
$string = "<select name=".$nombre.">";
if ($seleccionado=="")
$string .="<option></option>";
for ($i=1;$i<=$cant_registros;$i++)
$db -> next_record ( );
$value = $db -> Record[$campo_graba];
if ($valor_seleccionado == $db -> Record[$campo_seleccionado])
$string .= "<option selected value = ".$value." >";
else
$string .= "<option value = ".$value." >";
$string .= $db -> Record[$campo_lista];
$string .= "</option>";
$string .= "</select>";
return $string;
hope this helps.
Thanks
Shafi
May 08, 2009 | Computers & Internet
Funny UST scandal!!!
How to remove the virus:
first download taskiller in here or here and install it to your computer because you can’t use task manager to terminate the virus(the virus automatically close task manager).
run taskiller and left click it on the system tray(the one with a skull icon)
click processes
to close the virus, select process and click yes to the question
(process to close)
  1. killer.exe
  2. lsass.exe
  3. smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
  1. now, click “start” then “run”
  2. type “cmd” without quotes
  3. type “cd\” without quotes
  4. type “attrib -h -s smss.exe” without quotes
  5. type “attrib -h -s autorun.inf” without quotes
  6. type “start c:” without quotes (a new window will open)
  7. select smss.exe, autorun.inf, Funny UST Scandal.avi.exe and delete it
If theres any drive or a partition type “d:” in command prompt without quotes “d” is the drive letter then repeat the CMD STEPS number 4-7 above…….
  • now type this on the command prompt “cd windows” without quotes.
  • type “attrib -h -s smss.exe” (without quotes)
  • type “start c:\windows” (without quotes)
  • delete the file smss.exe
  • now, goto c:\documents and settings\all users\startmenu\programs\startup
  • delete lsass.exe
type “regedit” without quotes then delete the registry entries above….
“VIRUS REMOVE”
Or just simply download this UST VIRUS REMOVER (not tested)
Mar 20, 2009 | Microsoft Windows XP Professional With...
SD-P50A5 Pioneer TV - No Video and Audio is 'chirpy'
CHECK IT FOR CRACKED SOLDIER CONECTIONS ON IC2603 AND IC2604.
resoldier all heat sink parts , this model came of the manufactior line with manny bad solider conections.
regards.
daniel.
Jan 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Lexmark Wheelwriter 1500 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
