Hello I use verifone PCCharge, when I turn it on , an error message pops : "Password backup update failed.Shutting down PCCharge payment server"
PCCharge uses Access database, which is stored in .mdb file. Locate this file. Mine was in C:\Program Files\PCCW\PCCW.mdb.
- Back up this file.
- In the same folder where you found the database, there should be a program called VISDATA.exe. Double click on it to start it.
- Go to File > Repair Database, and point it to your database file (pccw.mdb).
- It will ask you if you want to open db, say no.
- Go to File > Compact Database, and point it to your database file.
- It will ask you if you want to compact to 2.0 or 7.0. I was told to use 2.0.
- It will ask you if you want to replace database, say yes.
- For encrypt, choose No.
- For open, say No.
- Close VISDATA.exe
- Try running PC Charge now.
- If it still gives you trouble, and if you don't mind losing all your history, move the pccw.mdb file out of PC Charge folder (C:\Program Files\PCCW\). Keep it somewhere else for backup, just get it out of PC Charge folder. Now, start PC Charge again. A new database will be created.
Posted on Jan 20, 2012
  • lanbradeen Mar 15, 2012
    You are awesome! Thanks for posting.
  • elena neustadt Dec 27, 2012
    help!! can u call me at 415-641-1440 right now? having the same problems but can't figure it out
Having the same problem. did you ever get it resolved? Thanks!
Posted on Nov 01, 2011
I just went through all the steps and PCPro loaded and I was able to at least sign in but then I get the following message:
Run-Time Error 3343
Unrecognized database format C:programfiles/pccw/pccw.mdb
Posted on Jul 16, 2014
This worked!
Posted on Feb 25, 2013
How can I find the password for tamper error on the verifone vx680
IF YOU ARE GETTING A TAMPER YOU WILL NEED TO HAVE IT REPLACED, HERE IS YOUR DEFAULT PW 1 ALPHA ALPHA 66831 ENTER
Feb 15, 2015 | VeriFone Vx 680 Payment Terminal
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
Runtime error 94 in pccharge
I just had this same problem, I managed to fix it by starting PCCharge and typed in "SYSTEM" for the user and then clicked the password box and selected "forgot my password" it should prompt you for a security question, and then it let me log on without issue. After 7 years of dealing with PCCharge I can honestly say it is **** and if you have any choice switch to another payment software. If not, best of luck and I hope your experience is better than mine. CHEERS!
Oct 11, 2012 | Go Software Inc. PCCharge Pro...
This isn't the latest macbook air, but its problem is that when I turn it on after a while after the apple logo appears, a message pops up saying, "You need to restart your computer. Hold down the...
This means your MAC is having a kernal panic, which could be caused by a failed update, a driver or program that is incompatible. You may need to start your MAC with your system cd/dvd and run the disk checker to repair hard drive errors and file permission errors.
I'm not sure what OSX version you are running but you could also try the steps outlined in this apple knowledge base:http://docs.info.apple.com/article.html?path=Mac/10.5/en/8965.html
If this does nothing, you will need to take it into a apple store for servicing, or reinstall the OS (you may loose your programs and data depending on how your reinstall)
Chris
Sep 08, 2011 | Apple MacBook Air
While opening the company an error message is showing " File: 'C:/Tally/Data/0001/Tr01324.900' Size;- 3100672 Possition; 3100672 (Done 512)"
THE PROBLEM U R FACING IN TALLY IS THAT THE DATA FILE OF THE COMPANY IS CUR OFT SO TRY TO REPAIR THE DATA FILE OR IF U HAVE A BACKUP RESTORE IT ON THE PROGRAM,ALSO REMBER TO BACKUP EVERY DAY OR WEEKLY AS POSSIBLE
Nov 13, 2010 | Computers & Internet
PC CHARGE - "INVALID EXP. DATE" ERROR MESSAGE ON 2013 & LATER
when you have PC Charge open, go to Setup and Preferences. A window will open. In the "maximum/latest year" or something like that, change 2012 to something later like 2016. That should fix it
Apr 15, 2010 | Go Software Inc. PCCharge Payment Server...
Verifone vx570 freezes on processing payments
Change your netgear to a d-link or linksys router. Your Netgear hates peripherals it is blocking the mac address. That should solve most of your issues.
The other is at your sales screen hit the number 6 and enter the password (1 Alpha Alpha 66831)
choose comms or sommunication then hit next until you see backup hit edit and then next until desired backup function appears under new. Hit enter or select then exit and then the RED X key until you get back to your sale screen. Reboot your terminal with the CAT5 or 6 attached and it should ease your problems as well.
www.greenlightpayments.com
Jul 23, 2009 | VeriFone VX510
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
Pccharge invalid trout id number
It sounds like your TroutD has somehow gotten out of synch with the last processed transactions. Usually, you can go to setup -> numbers and synchronize the TroutD to the last number used. This will usually correct the issue.
Jul 03, 2009 | VeriFone PCCharge Pro Full Version for PC
Computers & Internet Logo
7,849 people viewed this question
David Payne
David Payne
