Question about Westinghouse LCM-19v5 Monitor
Monitor works for a fraction of a second
When i turn on the monitor i can see my desktop for a brief moment and then it goes to black. no matter how many times i turn it off & on i get the same result. monitor is only a couple years old. is it shot? replacement monitor works fine.
  • mccarty8367 Oct 06, 2008
    momitor come on for a second you can see desk icons for a second then goes blank
  • garrett321 Dec 22, 2008
    I too have the LCM-19v5 monitor and have the same problem... It powers up, shows the DOS screen and WIndows xp screen, and then goes black...I checked the caps as recommended by this site and they look fine... nothing swelling/buldging... anything else to check?
    Thanks
    Problem Solver:
  • 5 Answers
See article written by sillybit (me) for the Westinghouse 19v5. My 20v5 had bad caps in the power supply - it did the exact same thing as yours. $8 worth of parts from radioshack and an hour or two is all mine needed.
Posted on Oct 09, 2008
The problem is usually one of two problems: the capacitors, or the inverter.
I have successfully replaced the caps and they were not the problem. Still the same problem after 2 hours of hassle, but a successful repair might I add.
So, the inverter is bad. However, that can also be fixed, so don't go throwing your monitor out the window just yet. The inverter is probably a simpler fix, however harder to track down a working part, and a little more $$$. Not too much more though. It's $5 vs. $15 - $30.
Take Care...I hope this helps
Regards,
Dave
Posted on Nov 17, 2008
    Scholar:
  • 66 Answers
Http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
Seems you have a backlight problem. The tubes oly last for about 30,000 hrs. The inverter and tubes should be replaced at the same time.
Take care
Kevin
Posted on Aug 02, 2008
I have a westinghouse LCM -17v2 SL monitor
when I plug it to 110 volt AC the separate power supply that comes with the monitor
click-off and nothing happen =monitor is dead no picture ,screen is black.
power supply model no:UP060B1190 110v/19v .
It look like there is a short in the monitor.
I tryed tocheck some parts in the pcbs but I give up because
I do not have no schematics .
thank you,
Charlie
Posted on Oct 28, 2008
I have a gateway dx4200-09 and when I boot up the screen goes black a few seconds after we turn it on and can't do much without visual have to constantly turn on and off monitor for brief glimpses
Either the Monitor or Video Card is going bad. Since it comes back on by turning the monitor off and on, I suspect it's the monitor.
If you have another monitor, plug it in and see if it works. If so, the problem was the monitor.
If you have another computer, plug the monitor into it and see if it works, if so, the problem was the video card.
Mar 26, 2012 | Gateway Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
LCD monitor from "LCD Universe"
Inverter unit inside the screen may be defective
Apr 07, 2008 | Computers & Internet
Westinghouse LCM-19v5 Monitor Logo
445 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
