Question about ASUS P4XP-X Motherboard
P4XP-X BIOS ROM CHECKSOM ERROR - ASUS P4XP-X Motherboard
How to booth up my cd-rom first
you need to set that up in the BIOS. Whe nthe computer is booting, tap DELETE. This will get you in the BIOS. From there you can choose the boot sequence.
Jul 11, 2011 | ASUS P4XP-X Motherboard
Mother board p4xp-x does not detect one tra byte hard
To installing a 1Tb hard drive inside your computer will not work because the BIOS configuration has a limit on the maximum hard drive it can support.
The only way you can use a 1Tb hard drive is to install it in an USB hard drive adapter case and then plug this adapter into the computer's USB port. The computer will see this as an external storage device.
Feb 20, 2011 | ASUS P4XP-X Motherboard
Bios problem,system not boothing in normal mode
Try downloading the latest ChipSet for your intel board, second go into the BIOS and set your clock...
easier than that, double click on the clock at the bottom right of your screen and set it to the correct time and correct time zone, click Apply and then OK that will get rid of the checksum error.
You're doing fine, don't give up on the new drivers. You are almost there....
Hope this does it for you my friend, good luck,
please leave rating, thankyou kindly
Apr 25, 2009 | Computers & Internet
In win set up
Hi!
You need to change the boot "boot from cd" to Boot from HDD"
You do that in the bios
So start the installation again, and when your pc starts to boot, get in to the bios and change the boot sequence to HDD
Good luck
Nic
Mar 04, 2009 | ASUS P4XP-X Motherboard
Boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Dec 10, 2008 | ASUS P4XP-X Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Tried to update bios on an ASUS A8N32SLI motherboard. System now crashes
ill suggest to recovery the system wind has lost his win32 files
do go for long t/s...........
May 22, 2008 | Computers & Internet
My motherboard has many troble since i bought it!
if you cannot give any description of the problem then there is no way to figure out what can be done please sent some description of the problem like restarting, errors etc
Dec 07, 2007 | ASUS P4XP-X Motherboard
ASUS P4XP-X Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
