Question about Tomtom TOM TOM ONE WE V3 GPS Receiver
Tom tom goes off when ignition is turned on.....could it be an earth problem in the car.it works fine when the ignition is off
  • 24 Answers
When the ignition is off its likely its drawing power from the tomtom battery - with the ignition on it may be getting a small amount of voltage from the car cigarette lighter to make it run from there, but not enough to power it properly.
I'd suggest replacing/seeing if you can borrow one of the car charger leads to see if that makes any difference. If not it may be in an issue with your cigarette lighter output in the car which can be checked by your local autoshop.
Hope this helps.
Posted on Mar 16, 2011
Vp commodore antenna goes up when ignition is turned off
recheck the wiring and connections and check for a proper earth wire on the antenna unit
Jun 06, 2017 | Cars & Trucks
Head lights, interior lights all work. I turn the ignition and everything goes out but as I release the turn they come back on. I checked the fuses replaced the ignition main fuse still have this problem.
Clean the battery terminals, may be a bad connection or the battery is flat.
If you take the terminals off, take off the earth (-) one first and put it on last, this will prevent any shorts that may cause some damage. Use hot water and maybe a little washing soda to clean the terminals. Make sure that none goes into the battery.
Sep 18, 2011 | 2007 Chevrolet Equinox LS New Cars
I ran a small tire pump from the ciarette lighter, it pumped some then stopped.Now the cig lighter doesnt work. My neighbor offered to help . his car did the same thing. I checked the fuse under the dash...
Try replacing the fuse with another of the same size eg 10amp. While you are under there check other fuses. The label is not always correct on Australian Toyotas, could be the same in your country.
If the fuse is blown, there is a short in the pump. Throw it away as it has blown the fuses in both vehicles. (yours and the neighbors)
Next time you are at a spare parts supplier buy yourself a cheap (usually under $10.00) LED computer safe test light. These are easy to use. It has a earth lead with a clip on the end and a probe on the other end that you touch to the fuse and see if it lights up the LED bulb.
First you connect the earth lead to a good earth, the ignition key while in the ignition is usually a good earth or a bolt that goes into the vehciles body. (You need a good earth)
Then you just touch the probe end to one side of the fuse and see if it lights up. If not you touch the other end of the same fuse and it should light up.
If only one end is lighting up the testers bulb the fuse is broken. (Yes it can look fine but be still broken)
If both ends don't light up move the earth lead to a bolt on the vehicle and recheck also check other fuses to make sure your have a good earth.
Tip, Some fuses only work with the ignition turned on while other work all the time.
You can also check the cig lighter with the test light. after checking the fuse is Ok
Again find a good earth bolt and attach the earth lead and place probe end into centre of empty cig lighter and it should light up the bulb. Becareful to to touch the side at the same time as this is the earth for the cig lighter.
Jun 12, 2011 | 1990 Toyota Corolla
Peugeot 306 stereo won't work when engine is running!!
Is this by any chance the original clarion (peugeot branded) stereo?
If so, try disconnecting the remote control stick from the back.
You may find it solves all your problems...
If not, you may wish to check the earthing of your cd player. It sounds like one of the wires may be earthing, or an earth may become live when you tun the ignition on.
Jul 11, 2009 | 2006 Peugeot 505
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Jun 27, 2009 | Tomtom GO 910
1992 toyota Corolla Temp gauge does not work
find the wire that goes to temp sender and apply earth to it turn ignition on the temp gauge should read hot if it does replace water temp sender if gauge dose not move gauge needs replaging
Jan 26, 2009 | 1992 Toyota Corolla
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Tomtom TOM TOM ONE WE V3 GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
