Question about Refrigerators
I want to know the rubber hose connection at the back part of the ref. near the motor
    Guru:
  • 683 Answers
I dont understand what you are trying to say. What is the problem or what are you trying to do? let me know.
Posted on Mar 16, 2011
Is this furnace a one or two stage
Hey Carole,
I cannot see the furnace so I cannot tell you...sorry.. If you give the great people on Fixya a chance... and provide the make, model, size, etc..etc.. someone might be able to help you determine what you are wanting to know.
Sep 18, 2017 | Heating & Cooling
Where is egrpressurefeedback sensor located on a 1999 ford ranger 2.5l
I believe it's on the right hand side near tranny dipstick. .simple thing to do is follow the egr steel exhaust tube from the back of the motor, the D.P.F.E will be off of that tube connected with 2 black rubber hoses and have a single electric connection.
May 09, 2014 | 2000 Ford Ranger SuperCab
What is the rubber hose that comes out of the t at the top of the loop of my dishwashers drain hose and what doese it connect to. The old drain hose I am replacing did not have that.
This hose?http://www.amazon.com/gp/product/B00379N7U6/ref=oh_details_o00_s00_i01
If so, the black hose is some part of the upgraded siphon. You can not order the old type hose anymore that I know of. So the only solution I know of is to replace your guide assembly which will have a tube on the top for that hose to plug into. There may be a way to 'rig' it to work without the updated guide assembly, but personally I am not taking any chances.
guide assembly:http://www.amazon.com/gp/product/B001DPFN4Y/ref=oh_details_o00_s00_i00
Feb 18, 2012 | LG LDF6920ST Stainless Steel 24 in....
How do i get it out to put new one in
find the offending carb or carbs by pulling float bowl over flow hoses to the side and starting motor, 1 or move hose will be pouring fuel, follow hose to offending carb, unmount all 4 carbs from motor,(unmount tank,1 bolt 2 hoses,2 wires) then (unscew hose clamps from front and back of carbs) next(reomove scew from very top font of air box,near metal cross bar behind fuel tank) then wiggle carbs to separate from rubber intakes,unhook trhottle cables pull carbs out one side(either side of bike) once off turn upside down,take 4 bowl screws out ,remove cover,take out small pin holding floats ,needle will come with it,use the right wrench and uscrew brass seat needle came out of(make sure any rubber o ring come with) reinstall seat &any orings take old needle off float install new one,put needle in hole of seat,pin float put cover back on bottom of carb,re assemble bike.I hope you've maked where everything goes,a little oilon rubber helps with reassembly .
Jul 17, 2010 | 1981 Suzuki GS 750 L
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
I need to know what kind of rubber gasket to use when replacing the back winshield the rubber fram is gone ane currently duck tape is holding the back window in place
only stateside ??duck tape/gaffer tape ,you will need to go to dealer to get a new rubber because the moulding is different on nearly every motor .Wonder the police havent pulled you over to check papers and search car then issue a denuncia for driving an unfit motor vehicle
Jun 15, 2009 | 1998 Toyota Corolla
SOMETHING BLEW OUT ON MY INTAKE MANIFOLD.
"blew out" is a bit dramatic...If it's a pcv hose it should have a ton of suction at the open end or where it had been attached.Also with that hose detached, your engine won't run at idle very well or at all. Most often, any hose that becomes disconnected stays pretty close to where it's supposed to be attached. Simply look for a clean attachment nipple near where you found the hose and put it back there.
May 30, 2009 | 1999 Chevrolet Blazer
Blower motor resistor
The blower motor resistor is located near the blower motor. It is held in place by 2 screws, and has a wire clip connected to it. Very simple fix.
I hope this helps you, and I wish you luck on your repair.
May 01, 2009 | 1995 Ford Thunderbird
Dpfe sensor broke in the REF tube
One hose is reference the other is pressure, the hoses are different sizes, do you have the factory high-temp silicone hoses required? they are different sizes so you can't mix them up, vacuum hose will burn up in short order, the failure of this sensor is almost always caused by excessive exhaust back pressure, you may have a cat converter starting to plug up.
Oct 11, 2008 | 2000 Ford Taurus
86 camry le
Verify near the door hinges there is a rubber boot (hose). Remove that and verify u don't have broken wires there.
If that's not ur problem, chances are it's the switch itself that's defective or sadly the motor is burnt.
Possibility that u have bad or corroded connections as well.
Get back to me if u have questions.
Jul 16, 2008 | 1986 Toyota Camry
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
