Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch SHE44C02UC/22 Loud noise in beginning and whenever water is draining out
3 Suggested Answers
  • 54 Answers
SOURCE: bosch shu43
sounds like your impeller/motor is going bad or something is stuck in that area.
Posted on Jun 25, 2008
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model she44c02uc goes
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer
Posted on Sep 15, 2010
The dishwasher will not empty
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 15, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Hello, My Bosch she44c dishwasher is not evacuating the water from the machine. I checked the line and i can hear the motor trying to pump. I've tried to make sure the impeller was clean, so at this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
When the dishwasher starts or when water starts to enter dishwasher there is a loud noise.
ther could be something stuck n your drain pump.
the way it works is first the unit drains,the it fills,then it start to wash. now if you hear this noise after it drains then it could be your water valve or after it fills when it starts to wash it could be your circulation pump. it depends on what cycle you hear the noise. let me know if this help by posting 4 thumbs up for this answer, thanks
Feb 28, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHX4AP05UC Very LOUD!
This doesn't add up to what other owners say. Have yo contacted Bosch? Also, your output line may be entering your drain system in the wrong place causing the noise for that issue. Good luck. I am looking at the same machine for purchase......
Dec 16, 2009 | Bosch Dishwashers
Bosch SHE4AM
i would check to see if you are using the factory drain hose or if you have extended the hose to reach the sink drain.
the only other thing that might cause this would be a restriction in the hose at the drain pump outlet, but check the drain hose first.
Sep 15, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
46 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
