Question about Samsung DV218AEW Electric Dryer
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
    President:
  • 3,074 Answers
Belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 16, 2011
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Dryer starts for 10 sec and then stops, has an burn smell it runs great Although when it stops it won't restart until a few mins later. Then the same over again. Its a loud noise when going for 10 sec
It sounds like it's overheating.
Find and clean the filter.
The noise might be something caught between the drum and the mechanism. A bra underwire is common if your female (anonymous)?)
Check with a good torch...
If you rotate the drum and it squeaks it's something jammed or maybe the bearing.
Apr 20, 2016 | Dryers
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Transmission is making a clanging noise and seems to be pulling
ck the fluid level 1st and read the dipstick some u have 2 ck. in neutral
Jun 04, 2012 | 1994 Jeep Grand Cherokee
2003 ponitac sunfire, almost 88,000 miles. Slowly was making a 90 degree curve when loud pounding sound started somewhere in the rear of car. Stopped & put it in park and revered the engine and there...
Sounds like a combo condition concerning your rear brakes and wheel bearings, if the noise was or is louder on right turns then left replace the right side wheel bearing and vice versa.Get this car to a shop however immediately as the ABS brake system may be trying to lock up the wheel that may be wobbling causing all sorts of havoc.
Oct 24, 2010 | 2003 Pontiac Sunfire
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
Samsung DV218AEW Electric Dryer Logo
194 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
