Question about Maytag Neptune MAH5500B Front Load Washer
When washer starts spin cycle it makes a very loud whining noise.
Its the Outer Tub Spinner Assembly bearing. The real problem is that it costs over $600 to fix the problem. Buy a new one.
Posted on Mar 24, 2011
SOURCE: GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Posted on Nov 17, 2007
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Posted on Nov 20, 2008
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Front load washer makes whining noise on spin cycle
Check to make sure that your machine is still level using a regular carpenters level. If it is not, You may be able to level it by screwing on the legs until it is level. But carefully and not too much at once.
Aug 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Apr 11, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
