Question about Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
    President:
  • 1,335 Answers
Run a cup of vinegar throught the coffee maker to descale the water system. Run an additional 2 pots of water to clear the vinegar. Flow should increase. Depending upon the amount of scale you may have to do this a couple ot times.
For severe scaling un a cup of the commercial descaler CLR and then flush the system with 2 pots of water. This should clear the system.
You should run the vinegar cleansing at least once a month or the recommended 30 pots of coffee brewed. This also depends upon the hardness your water supply.
Let me know if this helps. Thanks.
Posted on Mar 16, 2011
    Scholar:
  • 45 Answers
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
My Keurig coffee maker keeps flashing prime and nothing we do makes it go away and it wont make coffee.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 21, 2011 | Microwave Ovens
My Kuerig coffee maker putters out the coffee, there is no fluid stream of coffee like before. The coffee maker makes the sound like coffee will come out but then there is nothing but drops.
try runing a descaler throgh it first,see if that solves the problem, after a lot of use scale builds up in most applianced using hot water
Jul 29, 2011 | Microwave Ovens
My Mister Coffee adx 20 needs to be cleaned. Water goes through coffee maker at a very slow rate. I assume it is caused by mineral build up due to the water supply. Please advise
you should be able to clean it with a store bought descaler,but read the instructions before buying, or check with the assistant first.
Jul 28, 2011 | Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
Keurig say "brewing" but nothing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 03, 2011 | Microwave Ovens
I have a mr coffee thermal carafe coffee maker with a clean cycle button. can i use vinegar in it to clean?
Spirit vinegar is not only perfect for the job of descaling but environmentaly friendly.
Jan 01, 2011 | Microwave Ovens
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Dec 27, 2009 | Microwave Ovens
Microwave Ovens Logo
135 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
