Question about Video Game Consoles & Games
WHAT DO YOU HAVE TO DO TO FIX A FRUITMACHINE. WHEN YOU PUT IN MONEY IT JUST DROPS BACK OUT AGAIN
    Problem Solver:
  • 8 Answers
It's either 1 of 2 things. The coin mechanism or bill acceptor is malfunctioning, it will need to be repaired, if you can't see what's going on with it by looking. 2 - The machine itself has a problem, and is telling the coin mech/bill validator the machine is out of order, and not to accept money for this reason.
Posted on Apr 15, 2011
Love
Posted on Aug 07, 2012
Maglite 2aa back cap won't come off
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
Feb 03, 2012 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Tip
What to do when your cellphone drops in thw water...
If your cellphone accidentally drops in water, or get some wet due to raindrops. First thing you have to do is to take off the battery immediately.now if you can take off the cover both front and back, remove it,and let the water drained.now if you think there is still moist inside, apply some hot air, you can use a hair blower.Set it to the lowest temperature.make sure not to point directly on the LCD surface.or you can take off the LCD if you can.otherwise forget it if you don't have any idea.(ask for assistance)then if you think your phone is now free from wet.you can put back the battery and observe. If you found something wrong, take off the battery again and goto a good technician and let them fix it for you. hope you enjoy my tip.thanks for reading...
on Apr 13, 2010 | Cell Phones
I had smoke smell coming from my maytag washer..got a tech guy to come out and fix it..he replaced the belts..said not to overload the machine..put in the usual load..wasn't much...now it happened...
Could be the belts were not adjusted properly or the drum is not turning free or the transmission is bad . I would call the tech back and demand he fix it or give money back for belts.
Nov 22, 2010 | Maytag Washing Machines
New battery for my 2007 vstar, voltage drops over night to about 12 .3 which make bike hard to start, I put on tender last night and it started right up, should i take battery back for testing or...
Troubleshoot yourself first. Take a reading with fully charged battery and let stand overnight with leads OFF. Take a reading. Repeat with leads on. If less with leads ON, take out fuse and test again. You may have a live loom overnight doing the damage, otherwise get your money back. Cheers.
Apr 22, 2010 | 2007 Yamaha V Star Custom
Mobile LG gone into water - need repair centre in Sydney City or West
When a phone drops into water, first thing to do is to remove the battery, loose the phone, and dry with heat. Allow phone to dry very well and allow it to cool before you couple the phone back. After all these, put it back on and don't be surprised to see your phone working well again.
Most at times when phone drops into water and battery is not removed, or phone is not dried immediately, the panel in the phone will begin to rust and it might be hard to fix.
I wish you the best of luck.
Nov 16, 2009 | LG KU990 Viewty
Equium P200-1ED.
yes the fan can be changed before that your noise making fan can be fixed only you have to do is that unscrew the fan first take small brush clean the fan leafs and blow some air from your mouth to the bearings and motor part put a few drops of oil or 2-3 drops of oil in side bearings and slowly rotate your fan with your fingre to and fro so the oil can reached to the bearings and it will get lubricated wait for five mintues and fix the fan back in position and you can use it ot need to add more oil to it again add 2-3 drops thats all once the fan is lubricated it will not make any sound in the future this is applicable to all cooling fan it is must that once in a year you should lubriacte the fans for better perfomance and it will get more life too.....
Oct 12, 2009 | Computers & Internet
2000 blazer 4.3 hard to start (fuel problem)
Do you have the fuel tester hooked the in the overgrown air valve on the fuel rail in the back of the engine? Or do you have the fuel line unhooked in the back and hooked to the pressure pump? You want the fuel pressure to be in that 60 lb range so if you are hooked into the pressure valve on the fuel rail allowing fuel to go through, then I am betting it is the fuel pressure regulator. To get to that, you have to take the throttle body off and take the plastic plenum that covers the injector packs. On the back of the mount where your six pack of injectors are sits the pressure regulator. If it is faulty then it is dumping fuel instead of holding the pressure like it should.
Get a Chilton or Clymer manual and it shows you in pretty good detail how to fix it. I've done it to my 98 S10 with the same engine.
If you unhooked the fuel line so you are losing pressure from the line back to the pump then I would say your pump is letting fuel back to the tank when it shuts off. My money is on the first possibility though.
Good luck
Mar 28, 2009 | 2000 Chevrolet Blazer
WGR614 Drops Connection To Internet
How long do you use your router? It's better to put your router in a cool place. Sometimes router will stop or drop connections if its to hot..
Nov 19, 2007 | NetGear WGR614 Router
Putting back together the logitech extreme 3D pro
it was junk anyway, after about a year or two of service the spring will wear and you will have to send it into logitech, if they cant fix it they will then ask if you want a refund, i would say yes and just apply that money towards a new joystick. My friend had the same joystick and it wore out after two years. he disassembled it, and tried to fix the problem, then he reassembled it and then it didnt work period although everything was ok, so he just tossed it in the trash and bought another one.
May 26, 2006 | Logitech EXTREME 3D PRO TWIST HANDLE...
Video Game Consoles & Games Logo
225 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
