Question about Dishwashers
Where in western australia could i purchase a control knob and the handle/latch that needs to be lifted to open the door of dishwasher kleenmaid by brandt model no. DW 10W ?
  • Dishwashers Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
KUDS25SH DOOR WILL NOT OPEN THE LATCH FEELS LIKE SOME THING HAS BROKE OR LOOSE
Jul 12, 2010 | KitchenAid 24 in. KUDS25 Built-in...
How to replace a kleenmaid brandt dishwasher door handle
Go to www.espares.co.uk
Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
Jan 22, 2010 | Dishwashers
KUDS24SE KitchenAid door latch broke. How do I take the door apart
If the door cannot be opened, remove the the outside lower panel. (2 screws at bottom of panel, then lift off. Take a long screw driver (be sure power is removed first!) and push up behind the control panel at the latch at the very top middle of the door. You can them open the door and remove the screws that hold the control panel on. When the control panel is removed you will have access to the door handle and latch pieces. These parts can be ordered through sears partsdirect web site. Good luck.
Jan 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher mdc4650aww door latch very hard to open, replacement part
If the door latch mechanism is the only problem, (Meaning: although the door may be hard to open, it otherwise still works) you may only need to replace the latch and handle. The part number is 99003347 for the latch, and W10130694 for the handle. You can view a complete illustrated parts list at any of the following websites:
searspartsdirect.com
pcappliancepartspros.com
Just enter the model number you provided and locate items 3 and 5 under the "Control Panel" heading. If the switch itself is damaged, the part number is 99002751 and is listed as item 4.
To replace the latch, all you have to do is follow these steps:
1. Turn off the main power to the dishwasher. Dangerous voltage is still present inside even with the unit turned off.
2. Open the door and loosen the screws on the inner door panel that hold the operator console in place. NOTE: You may have to loosen some of the lower panel screws as well to accommodate getting the control panel free.
3. With the screws removed, you should be able to remove the control panel and access the door latch and handle.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 26, 2009 | Dishwashers
Handle is broken.. how to replace?
This is not a difficult repair. If the model number you have this listed under is correct, all you should have to do is follow these steps:
1. Turn off the power breaker, or unplug the dishwasher.
2. Open the dishwasher door and locate the screws around the perimeter of the inner door panel. These are torx, size T-2, I believe. Remove the screws directly behind the control panel and only loosen the remaining ones. This will enable you to remove only the control panel without having to remove the entire front panel facing.
3. If only the handle is broken, all you have to do is remove the the screws holding the latch assembly in place and lift out of the way. The door handle should lift out from the rear and a new one can easily be inserted.
4. If the latch assembly is broken, I would recommend replacing the small switches that plug into the latch assembly as well. They typically break when attempting to unplug the wires from the terminals, because they are so fragile.
Appliancepartspros.com has all the parts you need, along with some excellent exploded view diagrams you can use for reference. The parts that I am talking about are items 3, 4, and 5 under the "Control Panel" heading.
Item 3 is the Door Handle
Item 4 is the Door Switch
Item 5 is the Latch Assembly
Here are some more sites you may also try for cost comparison:
pcappliancerepair.com
repairclinic.com
If you have questions about this repair, or if the model number is not correct, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Aug 22, 2009 | Maytag MDB9600A Jetclean II Built-in...
Door locked shut
usually wind down window using torch and sturdy piece of wire or long flat blade scewdriver bend anti theft plate out of way of lock assembly (if still there) and using wire or screw driver move latch on release catch centre bottom area of lock assembly while holding door handle (outer) up to pull door open when you hit the right catch
Jun 29, 2009 | Mitsubishi Sigma Cars & Trucks
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
2003 toyota sienna lift door knob broken. how to open the ldoor
The handle that broke had a little 'finger' that actuated the release mechanism. The only way to open the back hatch is to remove the inner panel and push on the release mechanism.
Once off, you can either a) buy a replacement handle (expensive) or b) do what I did and simply make a piece of L-shaped metal to lever the release mechanism from the outside.
If your handle is completely off of the door you can look up under the little plastic cover (that hides the handle) and see the slot on the right side that the release handle inserts into. You need to stick the lever into that slot, and angle it down about 30 degrees from horizontal to get under the latch mechanism, which unlocks the hatch if you pry it upwards.
Jan 09, 2009 | 2003 Toyota Sienna
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
