Question about Wet International Q.E.P 4 inch Portable Wet Tile Saw
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
    Sergeant:
    Champion:
  • 250 Answers
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Posted on Mar 16, 2011
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How replace blade on 7 1/4 circular saw - Milwaukee
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
Sep 15, 2014 | Milwaukee Tool Saws
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
The blade on my B&D sawcat spins even with nut tightened. cold it be the blade is worn, but i put a new blade on and it doesnt spin as freely but still spins
Hole in the blade is greater than spindle on the saw, you did not put bush washer/reducer in, or if that bit is correct, you are puting holding nut wrong way in.
Do not use saw till you rectify the problem, switch off the saw, remove power cord from socket.
1. raise saw table up for maximum cut
2. retract slide-in protector to maximum
3. remove nut from spindle, following by blade (and bush if used)
4. check internalholding washer if it is correctly inserted.
5. orient correctly internal washer (it have notch or notches and will go freely only one way - check if that is the case)
6. insert blade, with reducing bush if required
7. if external washer is used put it in
8. screw in the holding nut, hand tighten and check mobility of the blade, tighten up about 1/8 to 1/4 turn with spanner, this should be sufficient to hold blade in place without any slipage. If slipage is still present, you are doing something wrong, you need then to supply me with exact model and I will describe exact part look and order in which they must go in.
9. connect to electrical outlet
10. short switch on and off
11. check blade for wandering and slipage, if none then make test cut
12. use as usual if 11 is correct
Hope this will solve your problem :-)
Aug 16, 2010 | Saws
I need to know how to change the blade.
Table saws come with tools for this purpose. You first must remove the plate next to the blade on the top. Usually held in place with two screws. Once that is removed you use the tools to hold the blade in place with one tool, while removing the nut holding the blade on with the other. Notice the direction the teeth are turning.
Apr 22, 2010 | Saws
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
10'' table saw binding?
Sounds like you lost a spacer that goes behind the first flange against the motor bearing, you could use a lock washer if you bend it flat.
Assemble:
spacer washer,
first flange,
blade,
second flange,
nut.
I think the first flange is rubbing the motor housing.
Apr 26, 2009 | Saws
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
Wet International Q.E.P 4 inch Portable Wet Tile Saw Logo
273 people viewed this question
Top Wet International Saws Experts
Tom Chichester
ray gallant
Are you a Wet International Saw Expert? Answer questions, earn points and help others
