Question about Sony PlayStation 2 (PS2) Console
Hy! I have a PlayStation 2 console type, and an LCD TV. The television is not amine composit RCA jack, and no scart connector. And this my problem. So now I can not use the console to my TV. The TV is located, USB, HDMI, DVI, and RGB connectors. Is there some kind of solution that can be mounted on the console to my TV? Thank you in advance for your help!
    President:
  • 1,623 Answers
You can buy a rgb cable for the ps2 search on ebay
Posted on Mar 16, 2011
  • 2 more comments
  • prutom Mar 16, 2011
    Thanx, but I don't have SCART connector, on my TV. I need an extension, as the mother, the composit (red, white, yellow), and rgb the father, what television can do. but I can not find such a thing :(
  • Martin Murray Mar 16, 2011
    that isnt what i said, i never mentioned scart!!! I said you can buy an RGB(which you say your tv has) ps2 lead like this and that then allows you to connect via scart or composite connection. Understand Now?
    http://cgi.ebay.co.uk/PS2-PS3-RGB-Scart-...
    I used to not be so stupid Aaaaah.... :DD
    I've seen a lot this kind of connector, but is distracted by a scart socket, which is on it. But now I realized :)
    So, no need to use the scart, only the father Composite, and RGB. The scart, as if there would be no. I am enlightened! Oh yesss :D
    MARTIN Thank you!
  • nieaha Mar 17, 2011
    How much. Is it
Can. U help. Me
Posted on Mar 17, 2011
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
RCA cable
Looking at the Target website, they offer an RCA cable that will connect your TV to either a Playstation or XBOX.
The cable is made by Monster Cable, and is called a Universal S-Video/Composite Cable for Xbox and Playstation 2. Target charges $20.79 +tax.
All of the Playstations, except the PSP, can use the same connector.
On the Target website, search for 10853408. That is the catalog number.
Other stores like Walmart, Best Buy, etc. may also offer this cable or one similar.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i set up a ps2 to a tv that only has a yellow and white input
It's called a "composite" adapter cable for PS2. The yellow RCA connector is composite video. The white RCA connector is left-audio (usually there's white and red for stereo - left/right)
There should have been a cable that came with your console, but in case you bought it used, here's a picture of what it looks like.
Also, you can buy one aftermarket:
http://www.amazon.com/MONSTER-CABLE-Hookup-PlayStation-PLG200/dp/B0000524PE
Look around, I wouldn't pay more that $15 for it.
Oct 03, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
