Question about Sewing Machines
I am having trouble getting the tension ajusted on my sewing machine and don't know what to do. My machine is an inspiration singer sewing machine have had this problem before but always was able to fix it now I can't.
    Problem Solver:
  • 5 Answers
You may want to start with a thorough cleaning and oiling. Be sure there is no thread caught in the bobbin case or shuttle, or upper tension springs. Check that your bobbin is wound evenly and with good tension, and that your needle is in right. The quality of your thread may have an effect, as well.
Posted on Mar 16, 2011
The hook casing that holds the bobbin in my Singer Inspiration 4205 will not rotate when I sew. Therefor the top thread can not pick up the bobbin thread.
there could be something wrong with the hook and hook race, it needs to be checked to see it the parts are damaged or need a adjustment
Mar 07, 2015 | Singer Inspiration 4205 Mechanical Sewing...
How to fix a hook & timing issue on singer inspiration 4205?
I would over ride the auto setting and trial and error the process by manually turning the tension my self, also it has to do with the fabric too, sometimes whatever fabric is being used tends to regulate the tensioner too, good luck
Sep 01, 2014 | Singer Inspiration 4205 Mechanical Sewing...
Thread tension not working
Bobbin is not inserted to spin the correct direction.
Also, it could be that the bobbin tension isn't correct either.
Feb 02, 2014 | Singer Inspiration 4212 Mechanical Sewing...
Bottom tention thread loose
try adjusting the top thread tension up one number till the stitches look normal
Feb 07, 2012 | Singer Inspiration 4212 Mechanical Sewing...
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
I have a Singer inspiration and am having the
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Dec 28, 2009 | Singer Inspiration 4206
Threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Dec 30, 2008 | Singer Inspiration 4206
I have a singer-inspiration machine and it appears that the thread keeps getting caught up in the bobbin area so my thread birdnests. I am new to sewing and this is a new machine.
Aug 23, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
