When i start my laptop ringing sound is comming. Is it a indicator of something???? touchpad not working once started till i press any key from keyboard.. Can you help me out please.
    Genius:
  • 1,189 Answers
Hi drpriyankash,
"Just follow these instructions for the "Touchpad,"
First, click on the "Start Button." when i start my laptop - paul7of9_108.jpg
"In the (right area), select to open the Control Panel.
Next in the [Hardware and Sound] category.
"Choose the "Mouse" paul7of9_109.jpg 'applet.'
Next, click on the"Device Settings" in the (Devices) block.
  • "Highlight" the item you want to (Enable) this being the "Pointer Device."
  • Click on the [Enable] button.
  • Be sure to (Click) on the "Apply, and OK buttons"
  • "You may need to "Update Drivers?"
  • Next in the "Mouse Properties" (window).
  • Open the "Properties,"
  • Now, open the [Driver] by [2x clicking] on it."
  • If the, Update Driver (block) is not "Grayed-out?"
  • Click to "Update Driver", and click the (OK) button.
"To Manually" Install Driver
Select to "Update Driver."
Next, select: ("Browse my computer for driver software").
Now, choose: ("Let me pick from a list...").
"Open the "Device Setting:
Click on the "Settings" button
"Try out some of the "Items listed" ->->
*Tapping, *Virtual Scrolling...
Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Posted on Mar 16, 2011
  • paul7of9
    paul7of9 Mar 18, 2011
    This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
Touchpad can't move
On most HP laptops there is a small button located near the touchpad that will enable and disable it.
Usually on other laptops there are F1-F12 keys located at the top of your keyboard with pictures on them and if you hold down the FN key (usually located near the spacebar or CTRL/ALT keys) and press one it does a function such as change the volume (usually indicated by speakers with sound waves coming from it). Usually pressing of the FKeys combined with the FN key will disable and enable the touchpad.
Jan 23, 2014 | HEWLETT-PACKARD Computers & Internet
Keyboard & sencerboad not\woring
If you mean the laptop keyboard and Touchpad are not working ?
the problem might be caused by the same issue for both.
Laptop keyboard and keypad not working
Laptop keyboards are a little more delicate than keyboards used in desktop computers. Hence they face more problems.
Normally, they are replaced when they render defective. However, most of these keyboard issues can be taken care of or even prevented by regular cleaning.
Common issues like, keys not working on your keyboard, having to press keys firmly to get the output or any keyboard typing issues, can easily be handled at home.
Sometimes you may find certain keys of your laptop's keyboard to not be working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result.
You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication.
Therefore you are supposed to maintain your laptop's keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
To start with, take out each key. Use a small screwdriver to carefully pry each key by making it loose.
As they become loose, keys will simply pop off.
Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water.
Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone.
This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
Once you have cleaned and lubricated all the parts, carefully reassemble the keyboard. Begin with placing all rubber components on the keyboard.
Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the keyboard in the above prescribed manner once a year, can prevent many such situations.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem.
This was all about solving your laptop keyboard problems that you can try out yourself. After trying all the above given options, if you still find the keyboard still not working, you will have to take your laptop to a service center to get it repaired
Touchpad Not Working in Laptop
Most modern laptops come with a touchpad mouse built into the computer.
If you've tried to use the touchpad and the mouse pointer on screen is unresponsive, chances are that you or someone else has accidentally disabled the touchpad using one of the Function keys on the computer.
To fix an unresponsive touchpad on your laptop, reactivate it using the Function key on the keyboard.
This process is different for each computer manufacturer.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
Hope this helps
Nov 22, 2012 | Computers & Internet
My mouse is not working on my laptop, it wont move
Hello debbiestar34,
Typically on a laptop computer there is an extra set of keys called the function keys. You will notice these keys are identified (usually) by a different colour of text on the keys of your keyboard.
You can probably find a key labeled "Fn" or "Function" in the bottom left of your keyboard, between the "Ctrl" and "Alt" buttons. Once you've found that key, look at your other keys and you should see one that somewhat resembles the touchpad on your computer or a simple rectangle with a mouse cursor inside it.
If you've found both of those keys, start by pressing and holding the "Fn" key, then press the one for your touchpad then release both keys. That should work.
May 25, 2011 | Dell Latitude D410 Notebook
How do you disable touch pad on new inspiron 15 R
Hi There,
In Windows 7 proceed as follows: (Click each one in order)
1. Start
2. Control Panel
3. Hardware and Sound
4. Mouse
5. Device Settings Tab
6. Choose touchpad from menu
7. Click Disable
To undo above, repeat the steps and click Enable
Regards,
Selk
Mar 27, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Computer starts but touch pad not working so no pointer so cant get into contol panel or programs
You will need to boot into safe mode - by pressing the F8 key once every second during bootup until you get an option menu and select "safe mode with networking support". Once it starts your touchpad should work - then you will be able to go into your Control Panel to re-install the drivers for the touchpad - Then reboot.
The other way is to use your "Start" key (bottom left on your keyboard between the ctl and alt keys) then TAB key to your control panel - and the space key in place of a mouse click.
Good Luck
Aug 01, 2010 | Samsung R610-64G Laptop
Touchpad won't work or enable
you are pressing the wrong key that's why.
Use this: Fn+F7, and start enjoying the laptop.
Have a nice day.
Apr 29, 2010 | Computers & Internet
Brand new computer touchpad not working
The blue light is mostly indicating that your touchpad is locked or 'off'. You can turn it on by pressing the 'Function key' (usuallly denoted Fn) and press one of the Fx (F1 - F12) keys with the touchpad lock option.
Jan 09, 2010 | HP Pavilion dv4000 Notebook
Touch pad doesn't work AT ALL!!!!
Hello there, Kasie!
Hopefully I can help. On laptops, there will *usually* be a "function button" one can press to disable the touchpad in the even that one wishes to use an actual mouse instead of the touchpad. -- This would be in the interest of not accidentally triggering clicks, or mouse movement when typing, etc.
Without knowing the make and model of your laptop, I can't tell you the precise button to press to re-activate your touchpad. On most laptops, you'll need to hold down the "Fn" key (usually at the bottom left or right of the keyboard) and then find the function key (top row of keys... F1, F2, F3, F4 and so-forth)... Look at your function key row. See if there is perhaps a key with a little "drawing on it" that looks like a touchpad.. like a horizontal rectangle with 2 smaller squares under the rectangle, representing the rectangular shape of the touchpad and the two "mouse buttons" beneath it... if you find something like this, it will likely be the one you'll need to press.
However, on some laptops, the button will be just above your touchpad... you'll be able to press it, and some sort of indicator light will either light up in red to let you know it's been deactivated, or white / green to let you know that it's currently activated.
One of my laptops which is an HP has the button at the top left corner of my touchpad.. I have to "double-tap" it to deactivate / reactivate the touchpad; while my Toshiba laptop has a button directly above the touchpad which I only have to press once. -- Both laptops have an indicator light as well. The HP's "double-tap button" will turn red / dark orange to let me know that I've deactivated it... With the Toshiba laptop, there is a light just below the touchpad area which is always lit up as a "bright white light bar" when active and simply not lit up when deactivated.
I wish you the best of luck with this, and hope I've helped you!
Apr 24, 2017 | Dell F3534 Touchpad
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Synaptics touchpad not working
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
