Sounds like the shock might be blown or ceased. Time to replace it.
Only two things could cause this...
A: the shock absorber is cactus, or
B:
bushes are siezed on your lower control arm.
To chech which it is,
you have to pull the wheel off, unbolt the strut on the lower end and
probly the sway bar from the lower control arm... see if you can move
the lower control arm up and down by hand if you can then its the
shockie... if you have a set of spring compessors then remove the spring
from the strut, stand the strut rite way up on the ground between your
feet and knees grab the shaft and then push and pull up and down nice
and hard to see if it moves freely... there sould be some resistance but
souldnt be stiff... the faster you push the more resistance you should
get.
Hope this helps.
Hi Check the height of the rear springs at the shackles fore and aft and compare the height. May be a broken rear leaf spring. If the back is lower it might be the leafs. Thank you for contacting fixya.com
Please get back to us if you have further query else please accept the suggestion.
Turn signal tail lights and BRAKE LIGHTS NOT WORKING
It
can be faulty brake light switch causing the problem or its blown brake light bulb.
First check and confirm brake light lamp is working and that's not
the case.
For turn signal not working it can be faulty turn signal switch or its issue with wiring:----
To
trouble shoot brake and turn signal related problem, check the help links mentioned
below:-----
Click
the link:----
1996 Buick Regal Grand Sport Brake light
Switch Location?
http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick?
http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to
replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work,
but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How
to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light
Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep
Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
1996 Chrysler LHS brake light circuit wiring
diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake
lights on 2004 Toyota RAV4?
http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver
side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
2007 KIA Rio: Brake Light Fuse Box
Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC
Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
2004 Ford Mustang: Brake
light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These
will help.
Thanks.
Thanks. Only thing is my car doesn't have leaf springs. It has a mult-link suspension.
Thank you for your solution. It was helpful
