Question about AT&T LUCENT / AVAYA CALLMASTER IV PHONE TELEPHONE BLACK COMCODE 847933850
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
Posted on Mar 22, 2011
Como habilitar mute
queria tmb
You may also use the following shortcut:
Dial ''1'' to exit programming mode and store the option as Enabled
(Mute Button, Record Out, Record Warning Tones), or
1-Line (Display) or the Per Plug setting (Headset Volume).
Dial ''2'' to exit programming mode and store the option as either
Disabled (Mute Button, Record Out, Record Warning Tones, or
Headset Volume) or 2-Line (Display).
Dial ''3'' to set the Headset Volume to the Per Call setting. (This
option is ONLY available for the Headset Volume setting.)
1-While on-hook (the headset must be unplugged), press 'SELECT'
+ The Light next To 'SELECT' Goes on.
2-PRESS 'MUTE'
+ THE CALLMASTER is in option Programming mode.
3Dial The 2-Digit Code, "68" ("MU").
+ The current Setting (Enabled or Disabled) is Shown on The display.
4-Dial * To chande the Setting.
5 when the setting you prefer is shown on the display, press # to save it an exit Programming mode.
DISPLAYING THE OPTIONS -------
To display the option settings:
1 While on-hook (the headset must be unplugged), press 'SELECT'
Select .
d The light next to
'Select' goes on.
2 Press
''Mute'' .
d The CALLMASTER is in option programming mode.
3 Dial the 2-digit code, ''00.''
d The display shows the option settings (three options are available
on the CALLMASTER III; four options are available on the
CALLMASTER II).
d The display will return to normal after approximately five seconds.
NOTE: Use the same procedure for international settings. However, you
must dial ''11'' instead of ''00.'' The top line of the display shows the
international settings, and the bottom line will either be blank or report a
problem with the (EEPROM) memory used to store the options an
Voc? tamb?m pode usar o atalho seguinte:
Dial '' 1 '' para sair do modo de programa??o e armazenar a op??o como Ativado
(Bot?o de mudo, Record Out, Record Aviso Tones), ou
1-Line (Display) ou a defini??o Per Plug (Headset Volume).
Dial '' 2 '' para sair do modo de programa??o e armazenar a op??o como quer
Disabled (Bot?o Mute, Record Out, Tons de aviso Record, ou
Volume fone de ouvido) ou 2-Line (Display).
Dial '' 3 '' para definir o volume do auricular para a defini??o por chamada. (Este
op??o s? est? dispon?vel para a configura??o de volume do auricular.)
1-o monofone no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
+ A luz ao lado ' SELECIONE ' continua.
2-PRESS ' MUTE '
+ O CALLMASTER est? no modo de programa??o op??o.
3-discar o c?digo de dois d?gitos, "68" ("MU").
+ A configura??o atual (ativado ou desativado) ? mostrado no display.
4-Dial * Para Chande o Ambiente.
5 quando a configura??o de sua prefer?ncia ? exibido no visor, pressione # para salv?-lo de um modo de sair da programa??o.
Apresentar as op??es -------
Para exibir as configura??es de op??o:
1 Enquanto estiver no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
Selecione.
d A luz ao lado
' Select ' continua.
2 Pressione
'' '' Mute.
d O CALLMASTER est? no modo de programa??o op??o.
3 Disque o c?digo de dois d?gitos, ''00.' '
d O visor mostra as defini??es de op??es (tr?s op??es est?o dispon?veis
na CALLMASTER III; quatro op??es est?o dispon?veis na
CALLMASTER II).
d O display voltar? ao normal ap?s cerca de cinco segundos.
NOTA: Use o mesmo procedimento para as configura??es internacionais. No entanto, voc?
deve discar '' 11 '' em vez de ''00.' 'A linha superior do display mostra a
configura??es internacionais e a linha de fundo ou ser? em branco ou relatar um
problema com a mem?ria (EEPROM) utilizado para armazenar uma das op??es
Oct 29, 2013 | Avaya 6408D+ 8 Button Display Telephone
I can hear but people can't hear me
Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 27, 2010 | Motorola Mobility H710 Bluetooth Headset
My I use my H 710 I can hear my customers but they can not hear me. How do I remove mute? Thanks
Aug 23, 2010 | Motorola Mobility H710 Bluetooth Headset
I can hear the other person but they can't hear me
Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
When I hit handsfree button it says it is muted cant figure out how to un-mute the phone
If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
Jul 04, 2010 | NorStar Meridian M7310 Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
Have bought BT Verve 450. Am looking for the MUTE
Hi, If you press the button phone book button - Looks like a book symbol.
Whilst in a call the handset will show "Mute On" press the button again to unmute.
Hope that helps.
For the BT Verve 450
Ryan - Worldhosted
Sep 15, 2009 | Uniden Cordless Phone
Disable the speaker button on a lucent partner 18d
It is not possible to diable the speaker phone but you can use the HFAI / Mute button to mute or unmute the spk. By default the spker phone is muted. Hope this helps.
Mar 12, 2009 | Lucent PARTNER18 Corded Phone
I can't figure out how to mute my Verizon LG Chocolate.
To mute your phone during a phone call, unlock your phone and the top left button should have the option of mute. Also the right button will say options, click that and the first option is mute. do the same to unmute.
Jan 05, 2009 | Verizon Communications LG Chocolate Cell...
AT&T LUCENT / AVAYA CALLMASTER IV PHONE TELEPHONE BLACK COMCODE 847933850 Logo
435 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
