Question about Husqvarna Garden
I need repair instruction to replace gas tank on Husqvarna YTH1848XP. Gas tank has leak and I need replacment instructions
boscia
  • 163 Answers
SOURCE: Replacement of gas tank on a Sears GT3000 riding mower
if theres no leak yet you can easily patch it with an epoxy puddy, available at your local auto parts store. i've used it myself on gas tanks, radiators, boats and its never failed me yet
Posted on Nov 30, 2008
spekgt
  • 60 Answers
SOURCE: Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
Posted on Sep 03, 2009
mowerman1857
  • 389 Answers
SOURCE: gas leak in sears lawn tarctor model
You will have to remove the seat and then the platform where the seat mounts, this will give you good access to the fuel tank. I know it looks like a daunting job but there are only about 8 or 10 bolts that hold the entire thing on and if you look it over before you start to find all the bolts, you can have it off it 10 or 15 minutes.
You can go here if the link works and see an exploded view of it:
http://www.searspartsdirect.com
Type in your model number then select Chassis and Enclosures
Posted on Sep 15, 2009
Testimonial: "very helpful answer "
  • 95 Answers
SOURCE: HOW TO REPLACE GAS TANK
No easy fix. Your on the right track, body comes off then usually 2 bolts that hold strap for tank have to be removed and don't forget to disconnect fuel line.
Posted on Mar 18, 2010
#1 Taper
  • 1040 Answers
SOURCE: I have a 323L Husqvarna
Try this link out to my Tip:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Jim
Posted on Aug 16, 2011
How to remove gas tank from Husqvarna model yth2242t
David, Not your exact model, links to chainsaw tank removal. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Removing the Gas tank from Husqvarna 350
Husqvarna 372XP tank removal YouTube
Stihl 044 project 2 Gas Tank Replacement
Aug 20, 2016 | Husqvarna Garden
Leak in the gas tank
Repairing a fuel tank can be dangerous so don't try to do it yourself. Any attempt to weld the tank will result in an explosion, even if the tank is completely empty; you can't get rid of the explosive fumes.
You'll be better off replacing the tank if there is a hole in it.
Feb 20, 2011 | 1996 Toyota Corolla
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
Replace Reliance Water Heater Gas Control Valve
there are no instructions for doing this.
how do you know it needs replacing? its rare that they need to be replaced.
I can help you, but need to know what is going on with the unit first
Apr 17, 2010 | Reliance & LP Gas Water Heater Control
New 445 husqvarna chainsaw will not start
Drain the fuel tank, look inside the tank to ensure that the fuel line inside still has a fuel filter attached to it.
Look at the on/off switch ensure that both the wires are still attached to the switch securely.
Check that the plug still has spark, if unsure replace the plug.
Check the air filter to ensure that it is clean.
Mix the gas 50:1.
Sep 17, 2009 | Husqvarna Garden
Hi there
Hope this help
Sep 03, 2009 | Garden
Gas leak on fuel filler neck, how can I fix this?
if it's a hose or pipe go to dealer or junk yard get another if broken clamp replace if neck part of tank call rad shop see if the can solder if you drain & pull tank
Aug 30, 2009 | 1995 Buick Regal
Husqvarna looses power after 10-15 min.
Hello Matt:
From your Description it Sounds like Either the Gas Cap is Not Venting the Tank, the Exhaust Port/Muffler is Restricted or the Rings are Worn Out and Require Replacing.
Make Sure the Gas Cap Allows Air into the Tank.
If the Gas Cap is Good, then
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then Most likely the Rings are Worn and Require Replacing.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 08, 2009 | Husqvarna 28cc Gas Line Trimmer
Gas leaking from carb
You have a stuck float in the carb.
Jan 11, 2009 | 2006 Husqvarna TE 250
Garden Logo
132 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
