Question about Home
Not Mirra but Mira! Seeking instructions for using Mira 88 (not Mira Gem 88) service pack.
3 Suggested Answers
Dissolu
  • 221 Answers
SOURCE: instruction manual for service gem 1000 washing
I know the place where to get it for $10. If you won't find anywhere else, just let me know
Posted on Jul 25, 2009
dttech
  • 4803 Answers
SOURCE: mira 88 service kit can not get outer casing off
Sorry, your question does not contain enough information for anyone to help you with your problem. For anyone to provide the information for you, they will first need to know the YEAR, MAKE, MODEL, and ENGINE SIZE of the vehicle that you want the information for.
It would also be nice to know WHAT service kit you are refering to.
Posted on Jun 16, 2012
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
Tip
IRobot Mirra 530 Setup
Setting up your Mirra 530 is easy!
  1. Use the power supply at least 12 feet from the pool
  2. Plug the cable into the power supply
  3. Place your Mirra in the pool, rocking it side to side to release air
  4. Once Mirra has sunk to the bottom, plug in the power cord into a grounded outlet
  5. Press the "Clean" Button on the power supply.
Mirra will start the cleaning cycle!
on Sep 17, 2013 | iRobot Mirra 530
Tip
Mirra 530 - How to Clean Mirra's Debris Canisters
Mirra is easy to clean. Watch the instructional video or follow the steps below.
  1. Lift the basket out of your Mirra
  2. Open the trap door and remove debris
  3. Use a hose to rinse remaining debris
  4. Replace the canisters.
That's It!
How do use my mira-cool portable cooler/heater no instructions or manuals
My mira- cool blows out hot air when I turn on cooler, do I need to fill container with water in the back
Dec 21, 2014 | Heating & Cooling
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Tip
Example: How to change your mp3 player background
Follow these steps to clean and maintain your Mirra for the longest life possible.
1. Ensure the Mirra is disconnected from the power-supply9_17_2013_4_42_42_pm.jpg
2. Rinse the filter as shown in the image below after each cleaning cycle.
You can also view a video here: http://www.fixya.com/tippage.aspx?thid=20133874&mt_f=tip_capture
3. Clean the scrubbing (roller) brush by removing any debris that might be wrapped around it.
  • Position Mirra upright (fig. 1 below), so you can view the scrubbing brush
  • Push the end cap of the brush inward, using a screwdriver, and pull out the roller (fig. 2 below)
  • Place the newly cleaned brush in the Mirra, snapping the end cap into place until it clicks (fig. 4 below)
4. Check the propeller as follows. REMINDER: BE SURE THE POWER-SUPPLY IS DISCONNECTED FROM THE MIRRA BEFORE CHECKING THE PROPELLER
  • Remove the filters from the Mirra (fig. 1 & 2 below), if not removed already.
  • Unscrew the propeller top cover using a Phillips head screwdriver, counterclockwise (fig. 3 below).
  • Remove the cover (fig. 4 & 5 below)
  • Remove any debris from the propeller (fig. 7 below). Note: there is no need to clean out the pump motor.
  • Place the propeller top cover back onto the robot (fig. 8 below)
  • Screw the cover back into place, by screwing the screw in clockwise (fig. 9 below)
5. Straighten out the floating power cord periodically, so it doesn't develop kinks over time.
Information acquired from iRobot Solutions
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Mira 88 service kit can not get outer casing off
Jun 16, 2012 | Cars & Trucks
Instruction manual for service gem 1000 washing
Jul 22, 2009 | Washing Machines
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
