How do I hook up Wii, regular xbox to led hd samsung television The wires are red, white, yellow. Got the sound and picture for the xbox but still no colour. Is there a way to hook it up without buying other cables.
  • dhippern Mar 16, 2011
    Got it working thanks so much for your reply!! :)
  • 902 Answers
You may have a bad yelllow rca cable for color make sure its plugged in right. or try plugging them into a different input. make sure all the right colors are matched up and pressed ALL THE WAY IN. if not you will need to upgrade your cables to svideo cable, hdmi, or component cable (the red blue and green cable)
Posted on Mar 16, 2011
Testimonial: "Very kind. Thanks so much for your reply"
  • 1 more comment
    Followed this
    in the component area o
    In back of tv connect wii's cables to the bottom row. yellow = bottom right with yellow circle and red and white to then going to the left and skipping 2 holes plug red and white into audio left and right . then set source on tv to AV
  • brian shevack Mar 16, 2011
    did that work
    oh i just read that glad it worked please if you would be so kind give me a thumbs up or write a review lol
I have no colour and crappy picutre with my wii hooked up to ou samsung HD plasma. Any suggestion how to adjust this? Alos, I have a red,white and yellow wire that is attached with yellow into green at...
try something else for the Wii to see if the unit is ok, to be honest it sounds like it is not hooked up correctly but since not there I cannot tell from your description.
Dec 21, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Just bought a new Series 5 Samsung 40" LED TV and we hooked up the DVD and the picture isn't clear. The midrange colours appear halftone dots like in a newspaper
do you have it hooked up through regular video? yellow cables or do you have a HD connection (HDMI, or composite cable, blue green and red) if not upgrade and you will see an outstanding difference.
Mar 29, 2011 | Samsung Televison & Video
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
I can't get a picture on my screen, but the auido still works
Make sure the Coaxial cables are hooked up properly. I don't know the HD colors right off hand but the normal colors are [RED Audio][WHITE Audio] and [Yellow Video]. Hope you get it hooked up with videos and sounds soon. Make sure that if your useing regular coaxial cables, your not hooking them into HD slots and Vice Versa
Jul 07, 2009 | Microsoft Xbox 360 Console
HOOKING UP XBOX 360 TO HDTV
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Feb 19, 2009 | Microsoft Xbox 360 Console
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Aug 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
