Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 600 washer will fill with water and goes into the wash cycle. It agitates, but never moves to the rinse and spin cycle. I turned it on and didn't realize until an hour later that it was still in the wash cycle.
    Brigadier General:
  • 6,277 Answers
(This is well worth a go!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
Rinse cycle not working on Kenmore 600?????
sounds like a program prob not familiar with this mech but it seems suspect
Mar 01, 2015 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Agitator not working 90 series model # 11026912691
    Hello aksward,
    Welcome to Fixya.
    Here are some suggestions for any Kenmore washers
    Let me know how it goes. I'm still thinking and searching my repair manuals!
    Huuum
    Please remember to leave a rating!
    KENMORE ELITE TOP LOAD
    Washer stops, won't fill, rinse or agitate
    • Check the following:
    Is the power cord plugged into a grounded 3 prong outlet?
    Is the indicator on the Cycle Control knob properly lined up
    with a cycle? Turn the Cycle Control knob to the right slightly
    and pull to start.
    Are the water inlet valve screens clogged?
    Are both the hot and cold water faucets turned on?
    Is the water inlet hose kinked?
    • Does the water level seem too low, or does the washer
    appear to not fill completely? The top of the agitator is
    much higher than the highest water level. This is normal and
    necessary for clothes to move freely.
    • Has a fuse blown or is the circuit breaker open? If problem
    continues, call an electrician.
    • Are you using an extension cord? Do not use an extension
    cord.
    • Is the washer in a normal pause in the cycle? The washer
    pauses for about 2 minutes during certain cycles. Allow the
    cycle to continue. Some cycles feature periods of agitation
    and soak.
    • Is the washer overloaded? Wash smaller loads.
    • Is the lid open? The lid must be closed during operation.
    Washer will not agitate or spin with the lid open.
    Oct 06, 2008 | Kenmore 22422 Top Load Washer
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 24032\24036 Top Load Washer Logo
    94 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
