Question about Metrik Car Audio & Video
Hello... I was just given a METRIK MCD-498 Stereo for my 94 Cadillac Deville because the one that I have in there now does not work. I have been told that I can connect the METRIK MCD-498 to my car somehow and just put the stereo under my seat because it is too much trouble to rip out the old stereo that came with my car and would cosmetically look really bad. When I was given this used stereo it didn't come with any cables or anything. Can you please tell me how I do this and what cables i need and where I hook them up at??? Also is there a website or somewhere that I can go to get a owners manual for this product?
KaeZoo
  • 156 Answers
SOURCE: Connecting remote cable to other port from the car stereo
You can tap the amplifier's remote wire into the accessory power lead at the back of the head unit. On most head units this is a red wire. Doing this will make your amplifier turn on and off with the key switch, rather than the deck power.
Posted on Jul 01, 2007
SOURCE: Car stereo installation
I had this problem as well. On my harness was a wire for connecting the factory amp. You have to connect the Automatic Antenna wire to the Factory Amp Turn On wire. Should be a blue wire to a blue wire with a white stripe.
Posted on Apr 14, 2008
SOURCE: car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
Posted on Jun 14, 2008
  • 138 Answers
SOURCE: how to hook up a turntable to a stereo
you might need a pre amp in between the turntable and the kenwood.. but you'll connect this on the aux IN.
Posted on Aug 05, 2008
  • 11 Answers
SOURCE: I have a CXSGT08HP sony
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Posted on Nov 29, 2008
Is there an alternator fuse on a 94 Cadillac deville
Hello Jamie Pickett,
External to the ALTERNATOR there is indeed a
"Generator Disable Connector" showing
advance of the (onboard) REGULATOR.
FREE Factory Drawings are available at
BBB Industries at (registration required)
BBB Industries Premium Alternators Starters Power Steering Products
Look under Engine, electrical: charging.
Parts
http://www.rockauto.com/en/catalog/cadillac,1994,deville,4.9l+v8,1025772,electrical-connector,alternator+/+generator+connector,2528
Hope this helps
Carnac the Magnificent
1994 CADILLAC DEVILLE 4 9L V8 Alternator Generator Connector RockAuto
Sep 01, 2017 | Cadillac Cars & Trucks
How to change a 94 cadillac deville licence plate light
Hello: First remove the license plate, Then remove the screws that hold the the plate that is behind where the license plate.
Nov 03, 2010 | 1994 Cadillac DeVille
I am trying to hook up a stereo in a 94 Cadillac deville would like to know how to bypass the amp.
bypass the amp??? u mean the amp in the trunk? buy a $5 connector at walmart for the car. disconect from the amp. connect the conectors to the scotch brand adaptor buy a lot of speaker wiring and runn each set of speaker wiring to the front including the power and ignition wiring the groung can be done at the front of vehicle . and wire it up as directed in the instructions.
Jan 07, 2010 | 1994 Cadillac DeVille
My 94 Cadillac DeVille has a coolant problem, what part(s) do I need and on average what would be the cost of part(s) and labor?
If you have a Northstar Engine, sorry to tell you buddy... Either HeadGasket blown, or pulled Headbolts.... Now cadillac repairs these engines for around 3000$ atleast in my area.... You can have a Local mechanic do it, but the headbolts must be Time-Serted http://www.timesert.com/html/gm.html
Jul 08, 2009 | 1995 Cadillac DeVille
Changing rear air shocks
yes u can, u will need one of suncore industries kits ($539.00) to do the conversion to standard shock strut system, u will also need the relay kit. Call them before u buy.
http://www.suncoreindustries.com/cadillac-pages/cadillac-deville/1994-1996/cadillac-deville-94-96-suspension-relay-connector-kit.htm
May 14, 2009 | 1994 Cadillac DeVille
Locked out of the trunk 94 cadillac deville
Is there a trunk release button in the glovebox?
Mar 26, 2009 | 1994 Cadillac DeVille
Deville 2001 Reverse chime and stereo stppoed working
The disc changer will still work it gets power from a different fuse like the power attenna.
Mar 05, 2009 | 2001 Cadillac DeVille
Cadillac Door Glass
I did look it up and I only see one part for the 94-99 vent glass for the rear door.
Nov 15, 2008 | 1996 Cadillac DeVille
How Do I remove the door panels in my 94 cadillac deville concours?
u have to remove the panel that has the door handle in it, remove the panel which has the window and the seat adjusters, unplug the wires and just lift the door panel and there u are.
Oct 02, 2008 | 1994 Cadillac DeVille
Car Audio & Video Logo
100 people viewed this question
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
