Question about LG 42PX3DCV 42 in. Plasma EDTV
Lg 42px3dcv plasma
My lg 42px3dcv plasma has audio but no picture.
  • coastie2003c Mar 20, 2009
    What is the Y-Sustain and how much does this normally cost to replace?
    I have the same TV and same problem. Was working fine then just picture went blank, still have audio.
    Problem Solver:
  • 7 Answers
Hey listen. Not too long ago I posted looking for help. I run a club -the facility side of it- and 3 of our 42px3dcv Lg's went bad in a 1 year period. I saved these hoping to find parts or cheap fixes one day, and it's paid off. I found Donberg Electronics -out of Ireland- and they had the parts for a really cheap price. You are probably not going to believe the price when you inquire. Veronika and Annette at Donberg are very nice and helpful. Going back to the problem, yes I am affraid you need to replace y sus, z sus and ctrl board. For that there is a repair kit you can buy where I just told you. If you are going to do it yourself it's relatively hard, as you have to memorize how the parts were originally installed, exactly. I would recommend having a buddy film the whole thing, seriously. You also have to maneuver a lot, between the cables and be extremely careful with wire connectors. Once you have completed the swap -all 3 boards- then you can plug back the TV and you will have your LG plasma back at work! I am not a technician but I have to tell you I run 3 different health clubs and have done everything from scrubbing showers to paint walls to install computer software and hardware -obviously tv repairs as well- So yeah, it isn't easy but it's worth trying. DO NOT MESS WITH ANYTHING IN THE BOARDS!! I MEAN IT!! Good luck and post a note if you think this was helpful. I am certain it is though. LOL. I've done it 3 times.
Posted on Jun 12, 2009
Need to replace the Y-SUSTAIN
Posted on Sep 21, 2008
Loud Pop and the Screen went dead on a LG 42PX3DCV plasma TV. 5 years old so out of warrenty. I took the back off the tv and checked all the ceramic resistors and the resister on the Y-SUS board has...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helpout in solving the problem....
May 31, 2011 | LG 42PX3DCV 42 in. Plasma EDTV
HALF PICTURE ON LG PLASMA MODEL 42V7
first check all of your ribbon cables. then check the lvds cable. if this dont fix then you will have to get a service manual and run the panel by itself to determin wich circuit your problem is in. any questions feel fre to contact me....
Oct 17, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
My sons friend polished his plasma tv screen with furniture polish and it has left marks is there anything I can use to get rid of them.
Damp a rag with warm water, and wipe the marks and buff dry with lcd screen cloth, they are different than regular rags. hope this helps.
Feb 04, 2010 | LG 42PX3DCV 42 in. Plasma EDTV
I have a minor scratch on my Panasonic Plasma is there anything I can do to make the scratch less noticeable?
A mean person would say sand it, but dear god dont do that.
Short answer is you can't, OR you could sand all of it?! :)
Oct 12, 2009 | LG 42PX3DCV 42 in. Plasma EDTV
LG plasma tv picture moves frame by frame horizontally
If the TV is still under warranty, I would begin there. The bad thing about a plasma TV is that they cannot be fixed. I would watch it as long as I could stand it. When you buy a new one, be sure that you a LCD HDTV or a projection. Sorry.
Jan 11, 2009 | LG 42PX3DCV 42 in. Plasma EDTV
LG Plasma TV has speakers fizzing in short bursts, cant hear any audio
Yes I believe you have a hardware failure in your audio amp IC. In some cases, a speaker will cause all the audio to distort, but its very rare for a speaker to cause this issue. If you just got it, you can return for a quick resolution, or contact a local repair center for a new main board replacement.
Nov 09, 2008 | LG 42PX3DCV 42 in. Plasma EDTV
LG 42PX3DCV 42 in.
Pixel misfiring (diffusion errors) are caused when the tv is not firing and erasing the pixels correctly. It can be caused by a number of things, usually a voltage or waveform is off somewhere. If you just bought the tv, return it and get another. If you are out of warrany, you can remove the back panel and run the tv to check the voltages. Don't touch the heatsinks! they're electrically hot and will zap you.. the voltages are labeled on the back of the plasma panel with a sticker. first check Vs and Va. sometimes you can check -Vy, Vset, Vscan and others if labeled on the board. If you have to adjust waveforms you need a very $$ o-scope and should get qualified technician to adjust. If a board is bad, its likely your power supply or Y-sustain pcb, and less likely your Z-sustain or contol (logic) board.
Nov 02, 2008 | LG 42PX3DCV 42 in. Plasma EDTV
Lg 50px4d
LG 42" Plasma TV 42PX3DCV Parts - YSUS ZSUS CTRL Part Number (set): 6871VSNB03E Part Numbers (individual): 6871QYH036D, 6871QZH041B, 6871QCH053G Part Number: 6871QYH036D Description: PCB ASSEMBLY, DISPLAY YSUS ASSY 42V7 FOUND THESE ON THIS: http://cgi.ebay.com/LG-42-Plasma-TV-42PX3DCV-Parts-YSUS-ZSUS-CTRL_W0QQitemZ110086231102QQihZ001QQcategoryZ116199QQcmdZViewItem HOPE IT HELPS
Feb 26, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PX3DCV 42 in. Plasma EDTV Logo
422 people viewed this question
Computer Repairing
Computer Repairing
