Question about HP Pavilion dv6000z Notebook
Screen looks like notebook paper - HP Pavilion dv6000z Notebook
  • Robert Gunter Mar 16, 2011
    By " screen looks like notebook paper" do you mean a bunch of multi-colored lines running horizontally and vertically across your screen?
    Sergeant:
  • 186 Answers
You can try an external monitor if the external monitor has the same lines then its the video chip on the mother board. But if the lines are not on the external monitor then it's the LCD on the laptop.
please Rate and vote Thanks, Hope this helped you.
Posted on Mar 16, 2011
How do i get an hp 650 notebook PAPER user manual?
Go to HP.com website look up your model then find support/download tab connect notebook to a printer download and print manual, or download to a file and open file when you need to look something up good luck if you ask HP for paper copy they may say do what I just mentioned you do.
Feb 11, 2015 | HP Computers & Internet
I have a dell insperion 1525...it powers up and seems to be functioning, but i have no display on the screen. It flashes one quick time on power up but then nothing. I tried running HDMI cable to my...
Your computer needs to be looked at by a computer technician as it is not POSTing or passing the Power On Self Test. As you are not able to get a picture on the TV with the aid of an HDMI cable I would say that your problem with the notebook does NOT lie with the LCD screen. It could be a loose connection between a RAM module and the mainboard.
One could remove both modules and clean the gold finger contacts of the RAM modules with tissue paper.
Take care!
damnor01
Jul 17, 2011 | Dell Inspiron 1525 Notebook
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
Jan 20, 2010 | Copystar CS-1500 Copier
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
LCD screen shows green shadows typically behind the cursor and eg on each alternate line when in windiws explorer page. It looks a bit like the old printer paper that had alternate white and green lines. ...
look for driver clashes or new drivers with this:
http://www.drivermax.com/
if there is none the i would say there is a loose connection in your monitor. I wouldnt reccomend taking it apart yourself however it fairly simple to fix and shouldnt cost to much to fix.
thanks
CBZ
Apr 26, 2009 | Dell Latitude D505 Notebook
Want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Apr 24, 2009 | Xerox DocuColor 12 Color Copier
Printing is very weak and difficult to read even though I changed and put a new cartridge in the printer It is a Lexmark X215
hi,
The resolution on a monitor is 72 dots per inch. The resolution on paper is about 300 dots per inch. What looks good on a screen often looks bad in print. The picture you are printing is probably saved at a resolution which looks good on the screen but not on paper.
are you using the right quality paper and are the printing settings adjusted correctly? If your printer is set for photo quality paper and you are using plain paper or vice verse, you wont get good results.
*please clean cartridges with the automatic system.
*Tried auto alignment setting
*Try to clean nozzles of cartridges by humid (wet) fabrics.
please try all the steps for the problem to be solved.
Apr 16, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Ricoh AC 104 copier
If the paper jam occured behind the toner cartridge, did someone pull it out and leave a piece behind the toner? Look to see if there is a small piece of paper jamed in the connector of the toner / developing unit. Also look for any small piece of paper in the paper path.
May 24, 2008 | Office Equipment & Supplies
No paper feed
what is the printer brand and model#? also try making sure the paper is in far enough and isn't sticking, and the paper guide is tight
hope this helps
Apr 09, 2008 | Office Equipment & Supplies
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
