Question about Nintendo Wii Console
How can i re connect the wii fit balance board to my wii ?
    Scholar:
  • 45 Answers
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
These sync settings will be saved even after the console is turned off.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.
Open the SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
Press and release the SYNC button on the console while the Power LED on the board is still blinking.
The Power LED will stop blinking and light steadily once the synchronization is complete.
Posted on Mar 16, 2011
2 Suggested Answers
SOURCE: my wii fit balance board won't turn on at all
you need to open up the back (After game is started) then press the red sync button on the board then quickly press the red button on the front of the wii. Same happenened to me and it worked fine.
Posted on Jun 17, 2010
Part way through a game, my Wii fit will say connection lost
1. Try replacing the batteries in the balance board.
2. Clean off your "Sensor Bar"
3. Move your "Sensor bar" to a location where it can better receive signals from your "Balance Board".
Jun 03, 2012 | Nintendo Wii Fit - Balance Board + Game...
How to connect the wii
Open the battery cover of the Wii Balance Board, you'll see a red "Sync" button. On your Wii itself, if you lift the SD Card slot you will also see a red sync button. Press the sync button on both the balance board and the Wii and it will connect.
Jan 11, 2012 | Nintendo Wii Fit Plus Red Game System...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
Wii fit balance board new batteries but will not respond to wii fit when button is pushed.
Does the light flash but not connect or does the light not flash at all? If the light flashes, you should try holding the sync button where the batteries go in the balance board and the sync button in front of the wii. I don't know what to do if the light doesn't go on at all though.
Sep 12, 2010 | Nintendo Wii Fit for Wii
Keeps showing loss of connection
do you have the wii fitness board 1 ft. away?
Mar 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
Jan 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii balance board weight differently after put on a wii board sk
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
Feb 26, 2009 | Nintendo Wii Fit for Wii
Want to use two wii fit boards at the same time?
You can't sync 2 balance boards to one wii.
I heard this is why but this isnt confirmed...
the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
hope this helps...
Feb 05, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
478 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
