Question about Uniden Cordless Phone
Where is the + sign on my cordless uniden phone? I want to make an international call but the operator doesn't let me through because the number cannot be dialed without the + sign.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
It's the same place as the - sign you use for local calls. That is, the + is simply punctuation inserted for readability. Ignore it when you dial the call, using only the digits.
Posted on May 28, 2012
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 8 Answers
SOURCE: Static on my pair of Uniden cordless phones (Model DECT1560)
Is your base near a computer or other electronics? Also, make sure your microwave is not on. I get static if I do any of those things.
Posted on Jun 20, 2009
SOURCE: I have a Uniden DECT 6.0 CORDLESS phone and the
The light in the upper left indicates you new messages. The light will flash until you clear all messages.
Posted on Jun 21, 2009
wiqi546
  • 1511 Answers
SOURCE: how to dial international number that rerquires
You can use 00 instead of + sign, IF not then press and hold the 0(zero) button will insert a + sign where wanted.
Regards, WAQAR.
Posted on Dec 25, 2009
Where is the plus sign on my uniden cordless phone
There are many types of Uniden phone.
When you ask a question, you need to give the MODEL number e,g D1788-2.
Only then will people be able to help you.
Jul 31, 2014 | Uniden Cordless Phone
Where is the + sign for a uniden cordless home phone
It's the same place as the - sign for local calls. It's just punctuation, used for readability. Just dial the digits.
Jun 03, 2012 | Uniden Cordless Phone
How to cancel voice message icon
Possibly an internal malfunction. I would try making sure all messages are erased after listening to them, then try the reset. If this doesn't work definately call uniden customer support for further support.
Mar 09, 2012 | Uniden DECT 6.0 Cordless Phone ID
How to dial international number that rerquires the + sign. where is the plus sign IN UNIDEN 1588-3T ??
You don't need to dial the "+". It's just punctuation. You don't dial the "-" in domestic phone numbers, do you?
Feb 14, 2011 | Uniden Cordless Phone
Have lost the operator manual for my uniden cordless phone system-can't alter the message answer system or recall how to save numbers
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download the manual.
Aug 07, 2010 | Uniden Corded Phone with 5.8GHz Cordless...
There is a flashing voicemail like sign on my Idect cordless phone but there is no messages. this is happening on all 3 phones can u help
If the sign is like a Cassette Tape, press MENU, then arrow up to Answ Machine, then OK twice. If the sign is like an envelope either press the up arrow until you have scrolled thorugh all of the missed calls (the numbers) or dial 1571.
Jan 21, 2010 | Uniden Cordless Phone
How to dial international number that rerquires the + sign. where is the plus sign?
Regards, WAQAR.
Dec 25, 2009 | Uniden Cordless Phone
I have a Uniden cordless phone EZI996, The lights on the base are blinking on & off bright red.
Hi.
Try the following procedure to reset and re-sync the phone system:
  • Disconnect all units from power.
  • Remove batteries from all handset.
  • Check all phone connections to base.
  • Check the phone connector underneath the base (RJ11 squared plug).
  • Put back battries on handsets.
  • Place handsets on base.
  • Connect base back to power with handset sitting on base.
If that does not fix the problem , then there is an internal fault. In that case call Uniden to arrange repair or replacement.
Uniden support number for your area is prited inside the user documentation.
Regards.
Dec 05, 2009 | Uniden Cordless Phone
We need a manual with directions for our cordless phones.
Hi Sir, Welcome to FixYa.
You can download it from the links below if you know the frequency at which it is operating:
http://phone.manualsonline.com/manuals/mfg/uniden/uniden_cordless_telephone_product_list.html
http://www.elitezoom.com/pdfmanual/uniden-phone-bcd396t-owners-manual-pdf.html
If you find posts helpful, answer 'Yes' below
Jul 06, 2009 | Uniden Cordless Phone
Uniden Cordless Phone Logo
142 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
