Question about Whirlpool Dishwashers
I HAVE A Quiet Partner model, built in, that I bought new in Oct 2010. I just had it installed last month, and we've used it 3-4 times since February in our new home. The green "Clean Light' stays on, or blinks all the time, even when it's empty. Last night, I couldn't get it to start a wash cycle. The other lights came on, and I pushed the start/resume button, but nothing happened! can you HELP me out? The door latch seems a little loose to me, too. Any potential problem there? Thank you. Oh, in case my office email blocks your response, try my home email: smitty200755@yahoo.com
  • Whirlpool Master
  • 2,605 Answers
Hello William,
Welcome to FixYa.
The clean light flashing indicates the control has sensed a heating fault, easy enough. However this can be initiated by several different issues depending on the model number so if you could provide a complete model number ( i.e. 665------- ) I can speak directly to what could cause it with your machine.
Having said that there is one thing that is same for all of the modern Whirlpool machines, if a wire has come off the heating element this error will occur.
If you remove the lower kick plate/toe panel, inspect the wires at the heater to be sure they are fastened securely, look to the very back behind the main pump.
i.e. ( again your's may look slightly different depending on model number )
Let me know what you find with that and we can proceed further with a model number if necessary.
Good luck and thanks for choosing FixYa.
Regards,
Macmarkus :)
Posted on Mar 16, 2011
  • Mark MacDonald
    Mark MacDonald Mar 16, 2011
    I didn't specify, but the wire for the heater in the image are located behind the device with the yellow wire harness ( thermistor ) cause your's may not have it.
    Regards,
    Macmarkus :)
Broken oil line, was there a recall?
seat heater and accelerator pedal,
  • TSB #TC-10-010 NHTSA ID #10032630
    • Date Announced:FEBRUARY 22 2010
    • Additional Info:How to Fix
    Summary: TOYOTA SERVICE CAMPAIGN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. ON CERTAIN MODEL VEHICLES EQUIPPED WITH A 2GR-FE (VE) ENGINE, THE RUBBER PORTION OF THE OIL SUPPLY HOSE FOR THE VVT-I ACTUATOR MAY DEGRADE OVER TIME. THIS CONDITION MAY
    More Information »
  • TSB #LSC-90-K NHTSA ID #10032631
    Summary: TOYOTA: ON CERTAIN MODEL VEHICLES,EQUIPPED WITH A 2GR-FE (VE) ENGINE, AN INITIATED PHASE 3 WILL REPLACE THE VVT-I OIL HOSE DUE TO THE RUBBER PORTION OF THE OIL SUPPLY HOSE FOR THE VVT-I ACTUATOR MAY DEGRADE OVER TIME. *PE
2007 Toyota Avalon TSBs CarComplaints com
Jun 26, 2015 | 2007 Toyota Avalon
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
I need the reset codes for my dishwasher. It gets stuck in demo mode at times. That's what the repair man said who came last time. My dishwasher is the Whirl Pool Quiet Partner I, Model Number...
Hi, this is the reset code: Push/Press 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later it will start working....
Jun 11, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Pliz can u help me unlock my usb modem its model is HUAWEI EG162G and its imei number is 353474028053130
Some time uninstall the software "mobile partner"
plug out your modem
reboot your computer
after the booting process come to quiet
then stick the modem into usb slot
it will install the software "mobile partner" again
Sometime these can solve the problem
Notice:
write down all setting you have made on mobile partner
although normally during the uninstall of mobile partner
the setting won't be deleted, that mean after reinstall of
mobile partner, the setting parameter is still available.
But just for safe, i write the setting down.
Sometime some virus like activity prevent mobile partner
from working properly.
Checkout the last software you installed, maybe uninstall
them can solve the problem.
Mar 09, 2011 | Computers & Internet
I bought a new Tucson 2006. The battery died in Oct 2009 and I replaced it, died again in May 2010, I replaced it, died again in Oct 2010 and I replaced it. Jan 10, 2010 it has obviously died again. ...
If the battery was made in china, Which walmart likes to buy from, I would go to another store and get one that will work for more than a couple of months. PS Don't get one from autozone either.
Jan 10, 2011 | 2006 Hyundai Tucson
Camera keeps shutting off even with fresh batteries...
NOT yet solved for mine ( bought Thnksgvg 2009 ) SAME problem .... for awhile ( about six months into moderate-use ) say early May .... .... several brands of batteries ....... THEN i changed to Energizer rechargbls .. and then that helped for several hundred pix ... BUT right now ( the last week ( mid-Oct. 2010 ) the CAMERA stays black .. ---- i might have more to say tomorrow .. ( Oct. 29 __ ) AFTER the Energizers finish REcharging ....
Oct 18, 2010 | Kodak EasyShare C913 Digital Camera
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
