Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
We just purchased the pediatric Vicks Warm Steam vaporizer and me and my husband have noticed in the morning after it's been on all night that it's leaving a residue on our walls and the ceiling. Is there anyway that this can be avoided ?
    Brigadier General:
  • 4,736 Answers
Try turning down the output to the lowest setting. If it's running throughout the night, it need not remain on highest setting.
Posted on Mar 16, 2011
Black chunks and water after use of V150SG Vicks Steam Guard Vaporizer.
The black specks could be caused by interaction between the heating element and mineral content in the water.
Mar 25, 2014 | Vicks V150SG 1.5 Gallon Warm Steam...
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I cannot sleep through the noise of the Vicks vaoupouriser. It sounds like a kettle boiling all night
does point to being scaled up with limescale there may be a scale remover recommended by the manufacturers i would contact them.
Sep 04, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No mist coming out at all
on the box there is a number for questions or comments : 1-800-VAPOR-1-2 ( 1-800-827-6712 ).
Mar 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
412 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
