Question about Port Designs Best Connectivity RS-232 Serial Port ExpressCard/34mm (SD-EXPC34-1S) Serial Adapter
I have APIOTEK EC-0008 serial express port card RS 232 it is not getting installed on my dell windows XP enviornment what is the reason
    President:
  • 1,623 Answers
Have you installed drivers for the card, as windows might know what it is but it wont be able to use it till the drivers are installed click below onto what version of windows you have and download the drivers
EC-0008
Windows 98/M2/2000/XP/2003
Windows Vista 32/64bit
MAC 8/9/OSX
Linux RedHat 7.3/8.0/9.0
Posted on Mar 16, 2011
Serial video cable driver for linux
Hey Anonymous! Unfortunately, the SSU-100 Single RS-232 Serial Adapter is only 'officially' supported on the following Operating Systems:
Windows 2000, Windows XP, Windows Vista, Windows 2003
To the best of my knowledge, there is not a Linux porting of the drivers.However there is a Linux driver package for the Quatech ESU2-100 (see below)
http://www.quatech.com/ManualsDriversFirmware/Communication/serqt_usb2_2.6_1.00.tar.gz
I doubt they are interchangable.
May 24, 2014 | Quatech SSU-100 Serial Adapter
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Is there any way to interace with USB
You will need 3 items to interface your Wizard with a USB port.
1. A generic USB to RS-232 adapter cable (with 9-pin serial connector, to match the connector on the OZ-730 interface cable).
2. A USB to RS-232 driver for the above cable. (If you have Windows XP: HL-340.EXE, contained in 111.rar, which can be downloaded from www.usbserialdrivers.com. If you have another version of Windows, or if you have Linux, you will have to consult the documentation on www.usbserialdrivers.com to find the correct driver.
3. Software to communicate with the Wizard. You should be able to use the software that came with it, or purchase RuppLynx, or download Microsoft ActiveSync or a similar free program.
I used a cable I purchased on ebay, the HL-340.EXE driver installer, and RuppLynx software to connect an OZ-730, an OZ-570, and a Zaurus 5800 to my Windows XP laptop without any problem.
Nov 13, 2010 | Sharp Wizard OZ-730
Can't get the PC to display on a TV through the RS-232 interface.
You can not connect a monitor to an RS-232. If your video card does not have a monitor output, you cannot connect a tv monitor to your computer... and the fact that it only shows the original monitor on the drop down menu tells me you can't add a TV to your system
Mar 18, 2010 | Acer Aspire 3000 Notebook
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
Digital 320 system requirements
The system requirements are: * MMX Pentium Class PC or equivalent * Microsoft Windows 95, 98, Me, 2000*, or XP** * Click Here for details on unique compatibility issues with Windows 2000 ** Click Here for details on unique compatibility issues with Windows XP * 16 MB RAM (32 MB recommended) * 50 MB available hard drive space * Available RS-232 (serial) port * 16 bit display card (24 bit recommended) * Color monitor * 2x or faster CD-ROM drive * Sound card (recommended) * Mouse
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Port Designs Best Connectivity RS-232 Serial Port ExpressCard/34mm (SD-EXPC34-1S) Serial Adapter Logo
412 people viewed this question
Top Port Designs Computers & Internet Experts
Martin Murray
Prashant M
Prashant M
shadowpro
Are you a Port Designs Computer and Internet Expert? Answer questions, earn points and help others
