Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
I cannot get the convergence alignment on my Sony projection TV model number kp-51ws510
  • 2 more comments
  • k_shriber Oct 05, 2008
    I can't get colors to line up
  • pounser Mar 13, 2009
    I purchased the repair kit and replaced both convergence chips in my Sony 57WS500 rear projection TV. I unsoldered and checked all of the resisitors and they all checked 4.6 to 4.7 ohms, and resoldered them as suggested. I unsoldered all of the 3.5 and both of the 5.0 pico fuses and they all had connectivity, so did not replace them. The TV no longer has the bowed red convergence, but all of the colors are now not aligned, a 3D effect. My remote has no ability to do any alignment, but on the front of the TV I hit an alignmnet button that has the target, but nothing really moves. What do I do next? Please help me.
    Yes, I have the orignal remote and do not see any menu or any settings I can go to that has anything to do with convergence.
  • pounser May 11, 2010
    I verified I have the original remote and still can't converge. My wife and I spent time on the Sony website and entered all kinds of special settings to see if we could get into the convergence set up and believe there are still problems with harware.
    I believe a possible solution are the tiny pins may have been soldered together. The only way I can be certain if one or more pins are suppose to be soldered together is lto ook at print out of the back of the board and compare with what it looks like now. Can someome tell me how I can get a detailed photo of all of the pins at and around the back of and specifcally around the back of the convergence chips, so I can unsolder and resolder them if ncessary.
    If anyone else has a suggestions, I am open to try anything before I throw my TV on the curb.
Ok, I used a magnifying glass and desoldered two pins which may have been soldered togehter and guess what, I fixed it. I had to go into the front focus settings and twick them to get the final 3D effect to go away. Anyway thanks to yoru website, I now have my TV back for about $65 compared to $500. but I did have to spend about 5 hours readings and working on the soldering. I could do much better next time.
Posted on Apr 03, 2009
  • Sony Master
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 31, 2009
  • Edward
    Edward Mar 13, 2009
    You need the original remote to do the alignment. Do you have it?
  • Edward
    Edward Apr 03, 2009
    None - I repeat - None of the convergence pins are soldered together. If you accidently soldered two side by side pins together desolder them and resolder them seperately.
    Also, make sure that you check the 5amp and 3.5 amp pico fuses by removing one leg on each one. If they are blown replace them.
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 picture swirls in the corners and is doubled
The tv have a problems known as a convergence problems,it dead.The tv have any colors lines R,G.B mis alignment,picture have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Sony KP-51WS510 51" Rear Projection...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv wont line up crosses and it is the same model kp-51ws510 51in
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 06, 2010 | Sony KP-51WS510 51" Rear Projection...
Convergence chip part# ?
Convergence chip used in Sony KP-51WS510 part number is as follows..
STK392-560 and Sony part number, 874901908
Available in Part Store.
Thanks.
Dec 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
