Question about Ricoh 6513 Copier
Konica 1015 how to reset f35 in konica 1015
  • 42 Answers
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Posted on Aug 02, 2008
  • Hadley Hudson Aug 02, 2008
    #1 solution was from me Mrbonz, I wasn't signed in so if you have anymore questions write back!Hope that helps.
Konica 1015 Papersupply indicator flashesand copy size indicator(s) when paper refilled or tray removed and replaced. Ok on rear operation.
Posted on Oct 09, 2008
Konica 3240 error code f35-1
Fusing failure check continuity of heater lamp and thermal fuse replace if busted if ok, go to tech. rep mode and reset the error.
Oct 22, 2014 | Konica Minolta 3240 Black Toner Cartridge...
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7020 F35 - 10 Where is DIP switch 3
In mode 25, pwr off then holding 2 and 5 down turn on. Service mode 25 has SW setting find 03-1 should read 03-1-0 not 03-1-1 (1) is a code F35-10
Jun 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code F34 on Konica 1015 copier is there any way to fix without service call?
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Ricoh 6513 Copier Logo
1,117 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
