Question about Honda Garden
Pressure washer wont start what am i doing wrong
  • 77 Answers
Problem with your pressure washer plz check your motor which make pressure (is pressure is ok or not)
Posted on Mar 16, 2011
Karcher wont start
there is a pressure switch in those machines that goes bad. it is a common problem. if its under warranty let them work on it. if not take it apart and you will see the problem. it is replaceable and you can do it.
Mar 28, 2014 | Garden
Hello i have a 6 hp briggs pressure washer and it starts fine and runs for 30 seconds and shuts off. it feels like the motor gets stuck when i try to start it again, but after a half hr or so it will turn...
You have to make sure you are pressing the trigger while you start the pressure washer. You should also make sure you are releasing the pressure at least every 30 seconds or the pressure will build in the pump and the engine can stall.
If it stalls with pressure in the pump and you don't relieve it by pressing the trigger, it will be very difficult to start. The pressure will slowly bleed off over time, which sounds like what you are seeing.
Jun 07, 2011 | Briggs & Stratton Gas Pressure Washer...
My pressure washer sat for one year with gas and it wont start i added fresh gas and tried starting fluid it starts for a couple sec and shuts off...What should i do?
I hate to tell you but the carb will need cleaning. Try draining the bowl to get the old gas out.
Good Luck it is not that hard to do.
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Apr 02, 2010 | Briggs & Stratton Gas Pressure Washer...
Pressure washer doesn't get up to high pressure
what model of pressure washer? is it sucking out of a barrel or is it on mains water pressure.?
do you have detergent on this machine?
a bit more info will help a lot.
bit like ringing the garage and saying my car wont start, what do you think it is?
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Washer fills up but wont spin
roof, if it fills and just sits there it could be the pressure switch, grab the end caps on each side of the consol and pull them off. Remove the two screws under them and flip the consol up. On the left side you will see the pressure switch with a rubber tube going to it. Get yourself a piece of tubing about the same size in diameter. After the washer fills, remove the tube from the pressure switch and blow into with the spare tubing. If the washer starts agitating, the pressure switch is the problem. Catriver.
Sep 29, 2007 | Kenmore 13202 Top Load Washer
Garden Logo
88 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
