Question about Western Digital My Book Elite 2TB External USB 20 Hard Drive
I bought this product few days ago. I cant retrieve WD 2T data, anything wrong with my USB 2.0? previously, i can access data and by sudden,it cant? does this mean that i do not use safely remove my drive during shut down? should i reformat it , if no solution, please advice thanks mr.tee
    Master:
  • 451 Answers
If you didn't save anything important yet on the drive go ahead and reformat the drive.
try and write data to it and retrieve it.
if it doesn't work as well return it.
Posted on Mar 16, 2011
I loaded 100GB of data on this EHD that was just purchased. It worked just fine loading the data and I could retrieve data right after initial load. The EHD was unplugged and sat for a few days. When we...
You're best bet is to extract the hard drive from the enclosure. Get a SATA to USB adapter (http://www.newegg.com/Product/Product.aspx?Item=9SIA1PU0ME3070). Connect that to your PC. If the problem is not with the HDD you should be able to extract any data without any issues.
Mar 08, 2013 | Computers & Internet
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My WD Elements hard drive stopped working suddenly and now I can't have access to it. I don't wanna go through the process of getting a data recovery software and spending hours trying to get a few...
1. Try to use a different USB Cable and test. 2. Open the external harddrive and replace the disk with a spare one or working one. Then test if it connects. a. If it does not connect then the problem is the electronic board of the external harddrive. Buy a Harddrive enclosure so as you could still use and retrieve your valuable data. Or slave the drive on your desktop computer and see if its connect. b. If it connects then you have a faulty harddrive. I hope you have a backup of what you have there.
Jul 20, 2011 | Western Digital 250GB ELEMENTS EXTERNAL...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
My WD800 hardrive fell down and now its not
Try connecting it to some other computer, and see if you can retrieve it. Also try a different OS too if it does not work.
May 17, 2010 | Western Digital External USB 2.0 80 GB...
I bought rosetta stone about 6 months ago, and i just opened it after about a month of non-use and it said i need to enter an activation code for "rosetta stone homeschool". everything other than the...
Did you purchase new or used? You are entitled to use it on two computers only. If someone has previously used it, you're in trouble. I personally ran into this. If it is new, call Rosetta Stone in Virginia and ask for customer service. They will walk you throgh the process. If you bought it used, make them cancel the previous activation. They may fight you, but it would be a restraint of trade to not activate you as long as it is not in use on another computer.
Oct 25, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
Dec 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
USB not woking
Based on your post/description, your USB drive is faulty. You can try salvage/repair it but chances are all data/information would be lost. If Windows can't do anything try using HP's USB FlashDrive Utility. File name "cp006049.exe."  Do a Google, download, install and execute.
Hope this be of some help/idea. Pls post back how things went or should you need additional information.
Good luck and kind regards.
Oct 20, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Western Digital My Book Elite 2TB External USB 20 Hard Drive Logo
171 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
