Question about Desa International Electrical Supplies
Need fan for RGH5500 generator. Part # 27003008. It's on a honda gx270. 9.0 hp.
    Problem Solver:
  • 11 Answers
I did a lot of searching and found these DESA suppliers for generator parts. Also, the fan for the MFD Part number 27003002 might be a substitute. See (http://www.masterparts.net/manuals/105202-01A.pdf then search for fan or 27003002)
Here are the MFD/DESA parts suppliers.
Baltimore Electric
1348 Dixwell Avenue
Hamden, CT 06514
1-800-397-7553
203-248-7553
Parts Company of America
1657 Shermer Road
Northbrook, IL 60062
1-800-323-0620
708-498-5900
Portable Heater Parts
342 N. County Road 400 East
Valparaiso, IN 46383
1-800-362-6951
219-462-7441
F B D
1349 Adams Street
Bowling Green, KY 42103
502-846-1199
1-800-654-8534
Master Parts Dist.
1184 Wilson Ave. NW
Grand Rapids, MI 49544-3458
1-800-446-1446
616-791-0505
Fax: 616-791-8270
Four Flags Power Products
1115 Stateline Road
Niles, MI 49120-4728
1-800-268-4983
616-684-2697
Laportes Parts & Service
2444 N 5th Street
Hartsville, SC 29550
803-332-0191
MTA Distributors
555 Hickory Hills Blvd.
Nashville, TN 37189-9244
1-800-264-0225
615-299-8777
Tuco Industrial Products
5223 18th Street SW
Lynwood, WA 98037-4506
425-743-9533
1-800-735-1268
Posted on Mar 16, 2011
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Nov 24, 2014 | Electrical Supplies
Honda gx400 parts
Honda GX400 either a motor car (which will have a '12V Generator' on board..) or a largish sized Honda utility engine for water pumps, fans and electricity generation of of over 5KW (5KVA)
Sep 09, 2014 | Honda Electrical Supplies
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
Clone honda 6.5HP engine
hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
Sep 12, 2009 | Electrical Supplies
Is it Honda the engine or the generator Proforce
Coleman usually uses Briggs& Stratton engine
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Am not getting electric to generator, its a Honda GX270 9 hp, Thanks for any help
Voltage regulator, rotor, or stator are at fault here. Flash the fields F1 and F2 to see if you can produce voltage. Flashing consists of connecting positive from a battery (9V or 12Vdc) to F1 and negative to F2 while genset is running. If voltage increases, then you will need a voltage regulator. If voltage does not increase, then you will need a new generator end.
May 03, 2009 | Honda Electrical Supplies
Electrical Supplies Logo
332 people viewed this question
Top Desa International Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Desa International Electrical Supply Expert? Answer questions, earn points and help others
